Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
camcorder bracket?
Old May 24, 2005 | 12:42 AM
cross_fire3's Avatar
Car: 83 camaro z28 cross_fire
camcorder bracket?
hey has anyone made a camcorder bracket to record straight out the windsheld for races or cruies or anything??? thanks
Old May 24, 2005 | 12:54 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
you mean like something that would go to a harness bar or cage or roll bar or just some double sided tape that goes to the dash board?
Old May 24, 2005 | 01:28 PM
TexasLT1's Avatar
Car: '92 RS
yeah I made one. I used 1/2" stainless tubing to make 4 posts, then used 1/4" plate to make brackets to mount to the inboard, rear front seat mounts and to the front bolt hole for the rear seats. 1/4" plate on top with a hole drilled in it holds the camera.
Old May 24, 2005 | 01:31 PM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
i made a nice working bracket for my camcorder.
i dont have a digital one so it is pretty heavy, so i made a stiff bracket to prevent shaky recordings.
i placed it right behind the rear seat right above the fuel tank.
if its zoomed out you can see me and the road, if you want a better view on the road just zoom in.
i can make a pic of it later and post it if you want.
if i can make a webcam under the front bumper or so and connect it to my camcorder, i can make pretty cool movies.
but i have to figure out to connect the 2 together, dont know how yet.
Old May 24, 2005 | 02:12 PM
i placed it right behind the rear seat right above the <a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp?si=22&k=fuel%20tank" onmouseover="window.status='fuel tank'; return true;" onmouseout="window.status=''; return true;">fuel tank</a>.
yea can you post a pic
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
