Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Lincoln Mig PAK15
Old Jul 29, 2005 | 01:35 PM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
Lincoln Mig PAK15
I'm just getting into welding and need one to learn on. I was thinking about this welder as it seems large enough that I shouldn't really ever need anything larger and it should be relatively easy to learn on. What does everyone else think? I'll be using it for body work and regular enthusiast stuff, exhaust etc.
http://store.summitracing.com/defaul...=egnsearch.asp
Good, bad?
Old Jul 30, 2005 | 01:49 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
That's all the machine you'll ever need.I've got an older version of the same welder and wouldn't trade it for anything.
Might check Lowe's,if theres one in your area,last I checked they had that machine a little cheaper.
L98Jerry
Dec 16, 2002 09:58 PM
TomP
Sep 27, 2002 03:43 PM
DTL504
Aug 13, 2002 01:16 AM
TomP
Apr 17, 2001 08:10 PM
Val
Sep 19, 2000 09:26 PM
