Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Replacing airbag steering wheel
Old Jan 3, 2006 | 08:39 PM
brutalform's Avatar
Im not sure if this in the right area, but I did a search on steering wheels, and what came up, were in the "parts for sale"board.
Im sure someone can help me out. I just bought a beautiful aftermarket steering wheel, to replace the ugly airbag wheel in my 92 bird.
I understand the conversion is straight forward, but what I would like to know is, after I disconnect the battery, and the yellow SRS wire, and change wheels, will my SRS light remain on? And if it does what can be done to turn it off? Thanks.
Old Jan 4, 2006 | 08:37 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
take the bulb out or maybe, depending on how the light knows the air bag is there, wire in a resistor of the same value that the airbag was, and it should go off, but im not familiar with the air bag circuit at all, so i dont know if that will wokr
Old Jan 22, 2006 | 12:18 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
just take the bulb out.. that will solve the problem..
Old Jan 22, 2006 | 12:56 PM
brutalform's Avatar
Ive found it alot easier to just snip the supply wire coming out of the DERM.
Old Feb 21, 2006 | 08:51 AM
chevylover5's Avatar
Car: 1992 Camaro vert
Engine: 355
Axle/Gears: 10 bolt... not blow up yet
u could always take the bulb out but thats a pain in the butt to do so just pull the SIRS fuse out of the fuse box then it wont light, maybe
Engine: 355
Old Feb 21, 2006 | 12:55 PM
brutalform's Avatar
No , it will still light. The only ways I know of, are, snip the wire, or remove the bulb.
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
