Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Any way to use LT1 heads on an L98?
Old Jan 24, 2006 | 06:33 PM
LT1FUN's Avatar
Just as the title says, I was wondering what exactly is required to run an LT1 heads/intake on an L98 block?
A friend of mine is buying my LT1 intake for his 3rd gen and I reccomended he go to LT1intake.com to find out what needs to be done to the intake in order for it to fit.
Now he's thinking of upgrading to LT1 heads as well and I was just wondering what would be the process of getting these heads to fit a 3rd gen.
Thanks in advance.
Old Jan 24, 2006 | 09:46 PM
bowtienick's Avatar
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
yes it is possible. there are two holes int the deck surface you need to plug, and you have to add external lines to a remote t-stat. if you have a gen 1 head to lookat you can find out what hole has to be plugged on the lt1, it sould be the only one that is different between the two heads.
Old Jan 25, 2006 | 10:35 AM
Vader's Avatar
This thread has the details:
https://www.thirdgen.org/techbb2/sho...hreadid=178262
lt500r55
Sep 1, 2021 01:30 PM
midge54
Dec 27, 2019 04:14 PM
CRFred
Feb 7, 2016 11:39 PM
midge54
Aug 29, 2015 09:51 PM
TheExaminer
Aug 19, 2015 10:07 PM
