Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
floor pans????
Old Feb 10, 2006 | 02:04 PM
3rdgenfever's Avatar
Car: 89 IROC-Z & 92 RS
Engine: 350 TPI & LQ4 408 in the works
Transmission: 700R4 & T-56
Axle/Gears: stock/ LT1 disc 3.42
floor pans????
I was wondering if anyone has ever put new floor pans in a third gen. Is there anything I should know first. Is it as simple as just cutting the old ones out and outting the knew ones in. Anything you could tell me would be awesome as I have never attempted something like this before. Thanks!
Old Feb 13, 2006 | 11:31 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
been done many times. heck, there are aftermarked ones available from year one. i did a search for you and ended up with a bunch of useless crap, and this one thread, it was a diamond in the rough, it has a picture.. and some good advice.
floor plans
Old Feb 15, 2006 | 10:30 PM
floor pans
Thanks for the help
Old Feb 24, 2006 | 01:06 PM
wiseman9986's Avatar
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
jusst do not skimp out on the seam sealer
Old Mar 2, 2006 | 01:50 PM
BABYBLUE_RS's Avatar
Car: 1992 camaro RS
Engine: 305 cu.in.
Transmission: automatic
Axle/Gears: stock
run a search i have a topic up on this
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LC2 TECH
Oct 13, 2015 11:53 PM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
