Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
increaseing airflow
Old Mar 25, 2006 | 11:54 PM
CarterCarbureto's Avatar
Car: 1987 Z28 camaro
Engine: 305 V8
Transmission: auto
Axle/Gears: 10 bolt pozi
increaseing airflow
any pointers on increaseing airflow to the engine, rad etc
Old Mar 26, 2006 | 01:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
oh which vehicle?
your air dam helps with rad airflow.
a cowl hood helps with engine air flow, if you seal it to your carb (so depends on cars induction)
Old Mar 26, 2006 | 08:27 PM
Engine: 305 V8
Transmission: auto
third gen camaro
Old Mar 27, 2006 | 09:32 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
remove fog lights if you have them. If you have louvered grill remove it and swap it out. both will allow more flow to the radiator while driving.
If you have a carb and a stock hood (not a louvered one) cut it and stick butterflied scoop on it. TPI get a ram air hood with functioning air box.
antman89iroc
36
Jan 31, 2016 08:42 AM
Nervous2
Oct 8, 2015 10:53 PM
gord327
Oct 3, 2015 01:25 PM
hartsmike
Oct 2, 2015 07:11 AM
