Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Antenna shaving question
Old Aug 6, 2006 | 11:43 PM
Casanova77's Avatar
This is probly a dumb question but here it goes. I want to shave the antenna off my 88 iroc camaro but after i do that where can i get a hidden or small box like roof mount antenna like the ones you see on the newer higher end bmws.
THANKS
PW
Old Aug 7, 2006 | 05:36 PM
fastcars's Avatar
Car: '92 Camaro RS
Engine: 454 Multi-port EFI Big Block
Transmission: T5-anyone have a T56 for sale?
Hey, I shaved my antenna off 4 years ago when I had my car painted. I used the antenna from a remote start system that I removed from a used car we had traded in at work. The antenna used the same connector as the one on my original antenna wire. I just routed it the same as you would if it was hooked to the remote start. Up the "A" pillar and above the headliner so you can't see it. To my surprise I also found my radio reception was equal to, if not better than what I was getting from my original antenna. Maybe your local stereo shop could source you one. However, I think I just got s**t lucky and found one that fit first time out. I've seen several other antennas since, but none of the connectors were the same.
Good luck.
Fastcars
Old Aug 8, 2006 | 02:38 AM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
they sell them at most of the auto part stores here in houston, they "hide
" in the back of the hatch, i have one in my RX-v6.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
redmaroz
Aug 16, 2015 11:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
