Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Need help finding 3/8-14 x 3/8-24 studs
Old Sep 3, 2006 | 01:57 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
I am making brackets for my alternator and steering pump and cannot find any 3/8-14 x 3/8-24 studs anywhere. I have some hexagonal tubing that I am making custom mounts with and need these studs so I can bolt them to the accessory holes on the heads and block. The tubing is 3/8-24 and the accessory holes I believe are 3/8-14 but they might be -16 thread. Either way I still can't find any studs. Let me know if you have a secret place to gets studs from. Fastenal, Ace, and True Value don't carry them.
Thanks,
Peter
Old Sep 3, 2006 | 02:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the threads are 3/8-16 and 3/8-24 good luck finding studs, maybe try going to a hardware store and purchasing all threaded rod.
Old Sep 3, 2006 | 03:54 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
I spose I can get plain metal rod and cut my own threads. If I want 3/8 threads what size rod do I want? The next size up correct?
Old Sep 3, 2006 | 07:05 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Well, low and behold, 3 True Value's later and I found them. Expensive little buggers at 3.00/ea but I got them.
New2Chevy
Sep 28, 2015 12:35 AM
MoJoe
Sep 15, 2015 12:50 AM
angel2794
Sep 8, 2015 06:22 PM
transaero
Aug 31, 2015 01:14 AM
LT1Formula
Aug 20, 2015 09:36 PM
