Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fuel cell in rear deck?
Old Feb 18, 2007 | 08:11 PM
fast89ta's Avatar
Car: 85 Camaro Z28
Engine: 408 ci bbc
Axle/Gears: 10 bolt 4.11 ratio
Upon removing the carpet out of my car, i found out that a previous owner got lazy with changing the fuel pump and hacked up the car. Thinking about what i could do to clean it up, i thought about possibly dropping the tank and cutting out the spot to drop in a fuel cell. I would have my buddy weld in a support for it and just leave an opening for the sump. Anyone have any negative thoughts about doing this, i havent really come up with any but ive been under the car putting my suspension on in the cold for the past couple hours while thinking about it.
Old Feb 18, 2007 | 08:43 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Why not just clean up the area he hacked up and have your buddy weld in a patch? Unless you race competitively and the sanctioning body requires it, I'd just do that. There's always other things to spend money on, right?
Old Feb 18, 2007 | 08:56 PM
DillonRager's Avatar
http://www.cardomain.com/ride/782913 get in touch with him on that one hes a member here too he did this and will help you anyway he can ,nice guy
Old Feb 18, 2007 | 09:00 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Just curious- why bother? Welding on a new panel or an access door would be SO much easier and practical.
Old Feb 18, 2007 | 09:24 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
80% of cars on the road have access panels for pumps, might as well buy one from jegs or summit and install that. They are nice with rubber gaskets and well designed. I never understood the "hack job" thoughts on this board. That piece of steel there is extremely flimsy and doesn't support anything.
Old Feb 18, 2007 | 11:27 PM
fast89ta's Avatar
Car: 85 Camaro Z28
Engine: 408 ci bbc
Im planning on putting a cell in anyway, its mostly gonna be a track car so im trying to cut out some weight here and there and im already running an inline pump so i figured id kill two birds with one stone. Its not something im doing right away and it will be covered up but it will still be in the back of my mind that its hacked up there. And it was a hack job, cuts arent straight and they used two little sheet metal screws and a whole **** load of glue to hold it somewhat back together. Plus i wouldnt wanna take the chance on hitting the tank while cutting the **** out, although when i changed the pump in my trans am on my back in the stones i was kinda 2nd guessing myself a little haha. Thanks for the input guys.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
mustangman65_79
Apr 14, 2017 05:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
