Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Doing away with flip up headlights
Old Feb 9, 2008 | 02:35 AM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
Mine dont work for starters, second they're not aerodynamic when up, third they kinda kill the lines of the car when up. Anyone have any ideas on a legal way to get rid of the flip up headlights on a 'bird? The smallest lights I can think of would be from an earlier GP or a Geo Storm(they're the same lights, some other GMs used these same lights too) but they're still kinda big. According to a guy selling them on ebay "The mounting housing is 6 inches wide X 3 1/4 inches high and 4 inches deep to the back of the bulb connector.The actual light itself is 5 1/4 inches wide by 2 1/4 inches high". I did a search and found someone who did it with non-dot approved lights but I wanna keep my car legal. Any fresh thoughts on this topic?
I found this hideous set-up for 'vettes on ebay:
http://cgi.ebay.com/ebaymotors/1997-...QQcmdZViewItem
but there has to be better looking set-ups out there.
Old Feb 9, 2008 | 02:50 AM
AmorgetRS's Avatar
Re: Doing away with flip up headlights
Unfortunately there isn't a lot of room to work with. You probably found my setup that wasn't DOT legal in any way shape or form. If someone made a plexiglass replacement for the whole assembly you might be able to cram a set of DOT lights under there.
Old Feb 9, 2008 | 02:55 AM
Yeah but there is'nt alot of room to work with on any car with flip up lights. We're an enterprising group we have to be able to come up with something.
Check out this RX7:
Normal:
[img]http://www.3rdgenrx7.com/images/blk/nose.jpg[/img]
Non flip up:
Is that sweet or what. Ive seen similar set ups on everything from 'vettes to fiero's, why not us?
o.k. I dont know why the first pic is making you click on it to see it but most of you know what those cars look like stock...if not click away.
Old Feb 9, 2008 | 02:58 AM
AmorgetRS's Avatar
I doubt any of those setups are DOT legal. I have never seen a good looking one for a Vette, they all stick up and make the car look like a frog basically. Why not a Thirdgen... well, because the newest that it wold be possible on are 19 years old (91/92 has a different setup and basically no room). There isn't much of a market for 1,000 dollar aftermarket headlights.
Old Feb 9, 2008 | 03:06 AM
The set up on the RX7 is DOT legal, it uses those Hella lights(which Im actually not fond of). $1000 lights? You gotta keep an eye on ebay. They pop up on there quite often and for quite cheap(for other cars, that is). Look at that ugly set I gave the link to in my first post. Dirt cheap.
Old Feb 9, 2008 | 03:14 AM
AmorgetRS's Avatar
Retail is the important part, those Vette lights are 1,200 dollars retail. Doesn't matter to the manufacture that they sell for 20 bucks on E-bay.
Old Feb 9, 2008 | 03:18 AM
Here's a C4, I dont know if the lights he used are DOT approved. Kinda look like driving lights, and they're ugly too, but its another example of what could be done. Just do it with lights that are already DOT approved.
Old Feb 9, 2008 | 03:22 AM
AmorgetRS's Avatar
The problem is that no lights of that height are DOT approved. Height in a non projector allows for control of the beam pattern that the DOT is looking for. You might be able to find some really small DOT projector that would work.
Old Feb 9, 2008 | 03:26 AM
O.k. these are overpriced but look what you can get for a fiero...a freakin' fiero for God sake!!
http://www.normsfiberglass.com/FlushMount.html
Here's a pic for the lazy:
I dont like projector lights. I wanna stick with rectangular lights like in the fiero pic.
Last edited by TheRealBlkBird; Feb 9, 2008 at 03:27 AM. Reason: Automerged Doublepost
Old Feb 9, 2008 | 03:28 AM
AmorgetRS's Avatar
http://www.sigmaautomotive.com/hella/50mmmodule.php
There is a 50mm projectors, which is like a little under 2 inches high. I wonder what lights they used in that Fiero.
Old Feb 9, 2008 | 03:35 AM
I dont know, I'll do a little digging and see if I can come up with anything. It seems like one of our members would be good enough with fiberglass to come up with the basic shell similar to the fiero's and for alot less then $500, heck I might even give this a try. Then like you said, the question would be what lights, then top the whole thing off with a clear piece of plexi and you have yourself a pretty cool set up.
Im a member of a fiero forum from waaaaay back, Im gunna see if I can post a question and see what the measurements of their headlights are...
Old Feb 9, 2008 | 07:11 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
To be honest, when are the headlights up anyway? Night time and maybe in the rain. Both times you are not going to need the aero as you are probably not racing it hard in either condition. Also, the rain doesn't leave too many people looking at the aesthetic beauty of your car's lines as it finds running to their cars trying to stay dry. The aero loss from your headlights being up is negligible. If you are trying to pin down that level of aero from your car, that would mean you have taped off every crack in the body panels, dropped the car to a non-drivable height, and no longer drive the car on the street. Otherwise that aero loss is unimportant even a little bit.
The problem I see here is not with the fact that the car is too ugly and non-aerodynamic when the lights are up as it is with the fact that the motors die and leave them up all the time. Fix the motors with the metal gears and the car looks great with the lights down and they come up when you need them to.
Old Feb 9, 2008 | 08:30 AM
To be honest for me, I find the car's ugly with the headlights up. Period. Forget aerodynamics. I just think flip up headlights are ugly whey they're up on any car with flip up headlights. Notice in my posts Ive shown an RX7, a 'vette, and a fiero, Id probably show more if I could find more that have been converted. So if you dont mind the look, hey good for you, Im looking for something different and I know I cant be the only one.
Old Feb 9, 2008 | 11:06 AM
Car: '87 Trans-Am
Well, if it is a personal preference only and you just hate the flip up lights, they have the Camaro :-p But seriously, it all depends on how much fab work you are willing to do then. To make it functional, DOT legal, and still look good is going to take more than just glassing up some buckets and slapping in undersized fog lights with a lexan cover. I would imagine one way to do it would be to get into the bumper some. Cut the opening allotted in the bumper for the standard flip up lights down more to allow bigger lights while maintaining the hood line. It would be best in that case to make a splash mold of the poly bumper so you can make a fiberglass bumper skin to work with as you would be hard pressed to work with the poly bumper to do glass work. Besides, if you made a fiberglass bumper and no one else has started making them yet assembly line style, you could start selling fiberglass bumpers as an after-market weight saving add on . Just one possible suggestion.
Old Feb 9, 2008 | 03:38 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
It'd be fairly easy to mount a set of hella 90mm projectors on and 82-90 car, they'll stick up more on a 91-92 car though. The 50mm ones seem like a cool idea. I would definitely like to get my hands on some of those.
Old Feb 9, 2008 | 06:00 PM
Actually, I never undestood why the Camaro's did'nt have something over their lights. Not only for looks but this time for aerodynamics too. Yeah, I thought about modding the bumper, seems like too much work. I guess I need to remove a headlight entirely and get down at ground level and see how much room there is to work with, without getting into the bumper, which I dont want to do. I cant imagine the Fiero set up working and something similar not working on a 'bird.
Old Feb 9, 2008 | 06:53 PM
'93- '97 Coversion
http://octanemotorsports.chainreactionweb.com/product_info.php?products_id=2739
Someone's homemade LS1 'bird's:
http://www.houstonperformancedriving.com/forums/showthread.php?t=20912
Old Feb 9, 2008 | 07:07 PM
Pocket's Avatar
Car: 91 Trans Am
My thoughts exactly
The only time I care is for racing at night
The track is always lit up so i just run the foglights
The are the same as the 82-90 Firebirds
Even the upper half of the housing is the same and interchanges
The lower half is different and swaps the motor sides IE Dr --> Pass
This was for a more compact package
Actually, I never understood why the Camaro's didn't have something over their lights. Not only for looks but this time for aerodynamics too.
Because the drag was negligible
Old Feb 9, 2008 | 07:27 PM
It would still look better. If you're happy with your flip up lights, you really dont need to respond to this thread some people like to modify things.
Old Feb 9, 2008 | 08:15 PM
jrs84ta's Avatar
Car: 1984 firebird
Engine: swapping lt1
I think what it comes down to is getting a lens molded to fit the car, after that figure out what kind of lights would fit in the lens. I need to take some measurements but I dont have my car its at a shop i want and try to draw something up in autocad I know someone who works at a plastics shop that does custom molding for windshields and and other stuff maybe he can help.
Old Feb 9, 2008 | 09:25 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Those look indredible!!
Old Feb 9, 2008 | 10:53 PM
Yeah, the entire front end filled with an intercooler kinda helps the attititude out also. Can you believe those are homemade?
Old Feb 9, 2008 | 11:09 PM
Stephen's Avatar
Car: 87 GTA
I prefer the "lazy eye" mod, over no pop-ups at all. Pop-ups are part of what makes our TAs. They justs pop-up TOO high.
Old Feb 9, 2008 | 11:32 PM
IF this is true would'nt the Fiero kit in the picture be a drop in kit for the 'birds too?
Old Feb 10, 2008 | 08:22 AM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
agreed, I'd love these
Old Feb 10, 2008 | 12:14 PM
Pocket's Avatar
Car: 91 Trans Am
It IS true, I own birds and Fieros. I have used both parts to repair each
I doubt it would drop in as the location of the light is different, the shape of the hood, slant of the hood
Also
The Bird has a cover mounted to the top of the light
The Fiero pushes up a flap door
You cant think it would be a direct swap
Old Feb 10, 2008 | 03:19 PM
Well...are'nt you special. If the door is the same, the shape of the opening on the hood has to be the same, that's just common sense. But I contacted Norman directly(Ive owned Fiero's too) and he said they've tried it and it wont fit in. No , I did'nt think it would be a direct swap but I thought with a little modification it could be made to work but Norman said it would be easier to start from scratch. Let me ask you, if you have no interest in this modification, why are you so interested in this thread?
Old Feb 10, 2008 | 03:27 PM
Stephen's Avatar
Car: 87 GTA
Surely you weren't being an A$$ enough to be responding to me. Can't tell because you weren't ballsy enough to quote WHO you were referring to. Instead, you post a blank reply.
I'm up for mods. If something does show up better that I like, I'm all for it.
Old Feb 10, 2008 | 03:53 PM
Car: '87 Trans-Am
I think he was referring to the guy Pocket's response higher up.
Old Feb 10, 2008 | 04:09 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
what about if you have fog lights, put a signal light in the fog light housing and a 4th gen sized headlight where the signal lights are. weld camaro hood corners over the flip up area?
ive seen zr1 vettes with driving lights down low.. maybe just do somhing down there and do away with the upper ones altogether.
Old Feb 10, 2008 | 04:13 PM
Stephen's Avatar
Car: 87 GTA
Headlights down as low as our fog lights are, would be "technically" illegal, and could fail inspection. I think our limit is 23", center to ground.
Besides, I can't imagine much good light output, on the road, with them being that low.
I've upgraded the output of my 87 fog lights, but as far as distance goes? They are nothing compared to my headlights. Granted, my headlights are upgraded too, but still....
Old Feb 10, 2008 | 04:49 PM
Car: IROC Z
Engine: 5.7
isnt there a guy on here that has a headlight setub on his ta thats got a headlight the same size as the signal, but just fills the space in the gap of the flip up? and theres also a guy with 4th gen style fogs in the bumper....
heres some more flip up conversion sites
http://www.breathlessperformance.com...53firebird.asp
testarossa did away with them for the 512tr and the 512m
http://www.sport-cars.org/site_img/l...ari-512M-2.jpg
http://pictures.topspeed.com/IMG/cro...F512M_1_0w.jpg
Old Feb 10, 2008 | 06:01 PM
Stephen's Avatar
Car: 87 GTA
That's what Redaif has on her car....
Old Feb 10, 2008 | 06:57 PM
Considering your post is 4 up from my response, I dont see how the hell you think I was talking to you. I did'nt think I would have to be "ballsy" enough to quote someone when Im responding to the person who made the last reply. Ive been on tons of forums and never had a misundestanding when Im talking to the last response without putting them in quotes. Im sorry but I did'nt see anything in your post worth responding to, Im not a fan of the "lazy eye" look, going way back to my Fiero days.
Old Feb 10, 2008 | 07:03 PM
Redaif's car looks bad *** but totally illegal, atleast where I live. Something like the Fiero's kit above that removes and replaces our headlight itself and replaces it with another DOT headlight might fly here.
Old Feb 10, 2008 | 07:07 PM
Stephen's Avatar
Car: 87 GTA
Yes, I was 4 posts back, but the one the posted 'I like the sleepy eyes mod better.'
Quotes negate any chances of misunderstanding. I've been here long enough to see PLENTY or cowards respond to a post from the page before them, and you hafta interpret which person they were referring to, because they don't have the guts to quote. So easy to hide behind screen names on the 'net.
If I misunderstood, I apologize. I just couldn't find anyone else to posted the preference after me, besides the quote of mine.
Old Feb 10, 2008 | 07:15 PM
Considering my post talked about the shape of the headlight and then went on to talk about Norman who's kit me and Pocket were discussing I thought it was self explanatory. Where any reference to your post was made I have no idea. Trust me, Im not going to hide behind anything. My post was made in response to Pockets post and Im not hiding behind anything, I just did'nt think I needed to quote him to make that clear.
Old Feb 10, 2008 | 07:34 PM
Just to show I have no hard feelings and to put another idea out there, here's and example of the "lazy eye" mod, its on a Fiero but if Im not mistaken this car is the first car to have done the mod.
[img]http://pff.hostkansas.com/pffimages/angle_eyes_2.JPG[/img]
Tell me why that did'nt work?
Nevermind, I get it now. Well, if your a member of Pennocks you can go look it up. To the rest sorry.
http://www.fiero.nl/forum/Forum1/HTML/043192-6.html
Old Feb 10, 2008 | 08:17 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Well I tried my hand at the lazy eye mod. I've since decided that I'm going to customize the headlights a bit more...
http://www.youtube.com/watch?v=nzZxMia5Ims
http://youtube.com/watch?v=xnu4mAgxPwk
Old Feb 10, 2008 | 08:37 PM
Stephen's Avatar
Car: 87 GTA
Why'd you stop? You got the hard part done already!
Old Feb 11, 2008 | 08:59 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
It wasn't that hard at all.....but the lamp I got was too tall for me...
Old Feb 11, 2008 | 09:02 PM
  #42
Stephen's Avatar
Car: 87 GTA
C'com...You can't say that, without sharing WHY it wasn't hard! Or HOW you did it.
Share with the rest of the class!
Old Feb 26, 2008 | 12:23 AM
  #43
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
isnt there a guy on here that has a headlight setub on his ta thats got a headlight the same size as the signal, but just fills the space in the gap of the flip up? [/url]
that was me.
https://www.thirdgen.org/forums/fabr...p+up+headlight
car has undergone massive construction since then. i now have hids too.
Old Feb 26, 2008 | 06:34 PM
  #44
Originally Posted by vejatabul
that was me.
Those look awesome but I have to pass an annual safety inspection which would mandate that the lights be DOT approved so I'll have to use headlights from another car and make those fit if I go forward with it. Ive got myself wrapped up in a different project right now anyway. Id love to see pics of your latest incarnation of your project though.
Old Feb 26, 2008 | 07:21 PM
  #45
soultron's Avatar
Car: 87 trans am
I didn't realize that penncocks forbid hotlinks....
Here's what I want to try.
Old Mar 2, 2008 | 10:43 PM
  #46
dualphoenix's Avatar
Car: two 87 Firebirds
Engine: 1-5.7L 1-2.8L
Axle/Gears: 3.73 and lsd
i did this mod about 4 years ago with my 93 probe just alot of molding and sanding and such but when it was finished looked like nissan 300z head lights also some one on the probe site did some that looked like acura integra headlights...all you really need to do is make a mock headlight bucket fiberglass it smooth it out cut round headlight buckets out seal your lights in the buckets get your lexan clamp it to you headlight lid slowly heat it and tighten the clamps to form the lexan to the body/hood shape mod the new buckets for the lexan and seal it all up..i have some pics of the start of mine i'll have to dig them up and post them..thought of doing it to my firebird cause i cant find a headlight module anywhere
Old Jun 5, 2008 | 08:04 AM
  #47
deebs067's Avatar
do u think this camaro hood would fit on a firebird if u got rid of the flip up headlights
http://www.hawksthirdgenparts.com/in...ROD&ProdID=119
Old Jun 5, 2008 | 08:34 AM
  #48
Stephen's Avatar
Car: 87 GTA
Firebirds have a different contour altogether from Camaros. No way ANY Camaro hood will EVER fit a Firebird. The flip up headlights is the least of the difference.
From the strut mouns rearwards, they are the same. From the strut mounts forward, the Firebirds are a few inches lower.
Old Jun 5, 2008 | 09:37 AM
  #49
mellis09's Avatar
they make an ss hood for a firebird.. a member posted a link to it, but i cannot remember the site.. i was thinking of putting this hood on my bird, i just hadnt found anyone who did it yet..
Old Jun 5, 2008 | 09:47 AM
  #50
Stephen's Avatar
Car: 87 GTA
Same place.....Hawk's. The "Super Duty" hood. http://www.hawksthirdgenparts.com
