Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Ever seen this?
Old Feb 20, 2008 | 09:53 AM
strokedZ's Avatar
Car: 1987 Iroc-Z
Engine: 383
Transmission: None yet
Axle/Gears: None yet
Ever seen this?
Just wondering if anybody has ever done this before? I custom made the inner fenders on my Iroc, cut em up, bent em up, welded em in, fiberglassed.....more fiberglass, bondo.....more bondo, sanded....sanded.... and more sanding haha. Anyway didn't know if anybody else has ever done it and if so wanted to see any pictures just to see how yours looked. Oh and by the way thats a spohn k member and a arms and they look awesome in there.
Old Feb 20, 2008 | 09:56 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Ever seen this?
i cant say ive seen that before. they look like they came out nice. I just dont know how they will stand up to all the flexing the strut towers do.
Old Feb 20, 2008 | 10:30 PM
AC's Avatar
AC
Car: Used to drive a camaro
Re: Ever seen this?
Very good custom work...however 86TA is 100% on the money. The flex that the engine bay will almost 100% see is going to reek havoc on your work. I hope it stands up for you but I think you may be seeing stress cracks appear over time (progressively worse with hard cornering or "diving" into corners).
Old Feb 20, 2008 | 11:36 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: Ever seen this?
Looks cool, but what was the real point? Just to clean up the engine bay?
A good STB like the edelbrock might help the flex problem. However, I would still feel hesitant about using "fiberglass and bondo" on any structural part of the car.
Just curious, is the rest of the strut tower intact under your added plates?
Old Feb 21, 2008 | 01:08 AM
strokedZ's Avatar
Car: 1987 Iroc-Z
Engine: 383
Re: Ever seen this?
its all welded in, overtop of the original inner fender and welded to that for support. Everything is welded and the only reason i fiberglassed was to smooth out the transitions from one piece of metal to the next and obviously a thin coat of bondo to make everything perfectly smooth. Its a strait line car so no worries about cornering or anything like that and i do have a strut tower brace to strengthen it some but it is very strong being that everything is welded in. Its pretty much to clean up the engine bay. All my wires for headlights are hidden, my overflow for the radiator and my windsheild washer fluid both have areas in the front corners which you can't see from the picture. Very clean look. I'll post a couple more pictures if anybodys interested in checkin it out to critisize, good or bad.
Old Feb 21, 2008 | 11:28 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Re: Ever seen this?
So you added weight to the front of your drag car for cosmetic purposes?
Looks good though.
Old Feb 21, 2008 | 11:37 AM
strokedZ's Avatar
Car: 1987 Iroc-Z
Engine: 383
Re: Ever seen this?
Looks good though.
haha thats what everybody says right after they tell me how cool it looks...... i know... i know... i figured the weight i lost with the tubular k member and a arms got put right back on with that stuff but its not a strip only car. Come on give me a little more credit than that haha. Built for showin off, cruisin, and friday night 1/4 mile.
Old Feb 21, 2008 | 01:16 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
Re: Ever seen this?
I hope your headers fit.
Old Feb 21, 2008 | 02:52 PM
AC's Avatar
AC
Re: Ever seen this?
AAAHHHH...welded on top of the existing...now that idea makes MUCH more sense to me than before. Good work again! I think its a very original idea.
Old Feb 21, 2008 | 03:04 PM
Car: 1971 Camaro
Engine: 427
Re: Ever seen this?
I don't see how this will affect header clearence.
Old Feb 21, 2008 | 03:14 PM
Re: Ever seen this?
You dont???
Old Feb 21, 2008 | 04:03 PM
Car: 1971 Camaro
Engine: 427
Re: Ever seen this?
Not at all. He did nothing to change the wheel well in the area of the headers.
Old Feb 21, 2008 | 07:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Ever seen this?
You dont???
he didn't extend the "frame rails" inward so there will be no loss in header clearance whatsoever
Old Feb 22, 2008 | 11:20 AM
strokedZ's Avatar
Car: 1987 Iroc-Z
Engine: 383
Re: Ever seen this?
i might take a couple more shots this weekend just to show how smooth the whole thing is. i dont even have a guess as to how many hours i put into it, bending and welding. Appreciate the criticism and compliments. Its not everyday you do something that nobody has seen before.
Old Feb 22, 2008 | 07:05 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Re: Ever seen this?
How do you get to all the wires and overflow tank and such when things start to break? I think it was done well but doesn't it make repair work harder?
Old Feb 22, 2008 | 07:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Ever seen this?
im quite sure the wires and overflow tank are not buried under the new panels. It would take a real idiot to do something like that.
Old Feb 22, 2008 | 07:48 PM
strokedZ's Avatar
Car: 1987 Iroc-Z
Engine: 383
Re: Ever seen this?
the wires were a pain to run under the panels but there is plenty of clearance just by popping the head lights out to get back in there. as for the overflow and washer bottles they aren't under the panels, just in the corner of the engine bay on opposite sides of radiator. Plus, they're both chrome so why would i hide them?
Old Feb 22, 2008 | 08:55 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Re: Ever seen this?
Well definantly take some more pics so we can get a better idea of whats going on. Looks like you're getting there.
Old Feb 25, 2008 | 09:51 AM
strokedZ's Avatar
Car: 1987 Iroc-Z
Engine: 383
Re: Ever seen this?
heres a couple more pics. they're a little blurry and i just got done blowing out my shop so everything is dusty but you can kinda see how i mounted the overflow and wiper fluid bottles.
Old Feb 25, 2008 | 11:25 AM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
Re: Ever seen this?
I have seen similar things done to a pure drag car but it was always with aluminum and riveted in.
Anyway it looks good!
