Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Sump question
Old Jun 1, 2008 | 02:49 PM
gtpro700's Avatar
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Sump question
I just bought a new tank and a comp engineering sump was wondering if you guys welded it on with a mig and if so how did you do it? Weld a few inches at a time and jump around to keep it cool? Any advice on how to weld it and where the best location for it will be is appreciated. Especially if any one has pictures or the location on the tank were they welded it as well. Also should I keep the factory breather and I have seen people weld on a AN fitting to the factory feed line is this a good idea for a return line? Thanks for the help.
Old Jun 1, 2008 | 03:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Sump question
first question is what condition is the factory lines, or are they new? Im quite sure the factory feed line is a 3/8" od tube, you can use this http://www.jegs.com/i/JEGS/555/100550/10002/-1
or this
http://www.jegs.com/i/JEGS/555/100551/10002/-1
if the line is in good shape.
as for the sump, i believe xplndbl3 has a sumped stock tank, maybe pm him
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
