Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
lexan rear window
Old Nov 15, 2008 | 06:16 PM
EchoMirage's Avatar
Car: 87 IROC
Engine: 383
Axle/Gears: no idea
lexan rear window
has anyone done a lexan rear window? any kits or write ups on it? i need to remove all glass for my road race series, but id like to maybe keep the hatch and have lexan instead of glass. anyone?
Old Nov 15, 2008 | 07:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: lexan rear window
There are kits available but I have no idea how they work. I did mine as a non show car, race only swap.
I cut out the seal lip and slid the Lexan under the body skin then secured it with plates riveted through the body skin. Close up you can see a few of the rivets around the window.
I made supports on the rear roll cage tubes to help hold the Lexan up. At the rear is some aluminum channel that the Lexan slides into. Because the window is under the body skin, no air can get underneath it.
I then fabricated a sheet of aluminum as a deck lid which covers the aluminum channel. The deck lid is attached with Dzus fasteners in case I need to access the battery.
Because the rear window doesn't have a frame, the Lexan will need to have some way to keep it's shape if used as a direct replacement. You would need an oven big enough to put the whole sheet in to mold it into the proper shape. My rear window is 1/8" thick which is very easy to bend but offers no support.
The back window and deck lid are very heavy but it also puts weight over the rear wheels. Changing it to Lexan makes a nose heavy third gen even more nose heavy.
Here's a complete premolded window kit. It's only $1100. The unmolded kits are $490
http://www.jegs.com/i/Percy%27s/760/01137-22/10002/-1
http://www.jegs.com/i/Percy%27s/760/8-01137-22/10002/-1
Old Nov 15, 2008 | 08:03 PM
EchoMirage's Avatar
Car: 87 IROC
Engine: 383
Axle/Gears: no idea
the rules for the road race series im in call for no glass at all......so there wont be glass over the rear anyway. theres no way im paying that much for it either way. thats more then the car cost. i may try and do something myself
Old Nov 15, 2008 | 08:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Find a notch back. There's actually one on Ebay with a starting price of $100
http://cgi.ebay.com/ebaymotors/82-92...Q5fAccessories
Old Nov 17, 2008 | 02:04 AM
UDAMON's Avatar
Car: Mazda Protege5
just a heads up on the notch. it is heavier then the glass hatch. i have one im looking to get rid of if your interested.
Old Nov 26, 2008 | 01:09 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Try these guys.. We use them
http://www.proglasswindows.com/
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
69 Six Pack
Oct 5, 2015 07:51 PM
t-top89
Exterior Parts for Sale
Aug 21, 2015 09:52 PM
