exhaust fab
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
exhaust fab
hey guys how would i make my exhaust 3 in longer without redoing the whole exhuast? i had to cut mufflers off and now tis to short. im running straight pipes to the axle to dynomax race mufflers. its 2 1/4 inch exhaust and 21/2 muffler. can i use a reducer and go from the 21/4 to 21/2 for the 3 inches then add the muffler?
Engine: 355
Re: exhaust fab
can i use a reducer thats same size as muffler, weld it flush with the muffler and have exhaust pipe slip inside and weld?
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Re: exhaust fab
Hard to picture but it sounds like a really easy thing to do yes by the adapter and bolt or weld it up just check if you need inside diamiter or outside diamiter sizes.
david068513
Sep 18, 2015 10:36 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
