Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
please help
Old Jan 31, 2009 | 12:43 PM
tgk7203's Avatar
please help
lost they key for my lug nuts and need to get my tire changed I think its a factory lug lock can I buy one any were thanks theo oh by the way it is a 92 maro rs
Old Jan 31, 2009 | 01:51 PM
christian'sZ's Avatar
Re: please help
if you have no luck finding a key, use a stick welder. on low setting center a open lug and tac small bead onthe inside ,let cool gently, remove with 4way. to protect wheel from welding splatter/slag, smear copious amounts of past wax on wheel. to clean just rub; and rub and rub and rub. you wont lose another one.
Old Feb 1, 2009 | 01:27 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: please help
You might be able to grab it tight enough with locking pliers, then use a cheater bar.
