Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Steering?
Old Feb 1, 2009 | 12:43 PM
IROCDU's Avatar
Steering?
Hi Guys.. I have a 1987 Iroc L98 camaro and the steering is VERY loose. I dont like it.
Do they sell something to tighten the steering up or is there some type of adjustment?
Please help. I dont want to sink alot of money into this car. I just got rid of my race 01 camaro and my 69 camaro. Just want something to cruise around in and be happy.
Old Feb 2, 2009 | 08:08 AM
kcb37's Avatar
Re: Steering?
You will need to check the steering componets.
If it's all going it's going to seem like your sinking money into it, but if you buy an old beat up car, that is how it's going to start. Once you have it fixed it will just be regualr maint.
Old Feb 4, 2009 | 12:21 PM
IROCDU's Avatar
Re: Steering?
do they sell a kit for an upgraded steering?
Like the Ididit steering column?
Old Mar 19, 2009 | 02:50 AM
firebirdowner89's Avatar
Car: 89firebird
Engine: 355 TPI
Transmission: world class T-5
Axle/Gears: 3.73 posi
Re: Steering?
yeah man on the top of the steering box their is a hex bolt with a lock nut.. loosen the lock nut then run the hex bolt all the way down till it bottoms out then back it off 1/4 to half turn then tighten the lock nut up and that should stiffen ur steering back up
Old Mar 19, 2009 | 07:44 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Steering?
and replace the rag joint.
Old Mar 31, 2009 | 10:27 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Steering?
Before adjusting the gear-box, I'd check all the tie-rod ball-joints.
Have someone move the steering wheel back & forth over the
"loose" travel, and see what moves most, the steering box input
shaft vs. the pitman arm, or pitman arm vs. axle steering arm.
Good luck,
kk
Old Apr 1, 2009 | 08:56 PM
99b4c's Avatar
Car: 99 B4C, 89 RS
Engine: LS1, 2.8
Transmission: 4L60E, T5
Axle/Gears: 3.23, 3.42
Re: Steering?
You have to check out the steering on a lift, most likely a centerlink but could be an idler arm or inner and outer tie rods or all of it.
Old May 1, 2009 | 07:46 PM
Gdav's Avatar
Car: 87 Iroc Z-28
Engine: 350 tpi
Axle/Gears: 3:27
Re: Steering?
Hey man I got same car with same problem . I Just got finished within last couple months with ball joints, struts, and alignment. My steering was okay, but they told me same thing about steering box when I got it aligned. Were you able to figure yours out yet ?
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
