Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
under hood insulation
Old Apr 5, 2009 | 05:27 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I read about removing underhood insulation and replacing it w/reflective insulation; the 3m stuff reflective. My iroc insulation is old and shaggy. Does anybody know about doing this? Any other suggestions besides buying a new one for $85.00??
Old Apr 5, 2009 | 06:05 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Re: under hood insulation
Could always paint it, did that with my stock hood before my paint job and my new hood. If your worried about heat you could use heat-resistant paint or heat-resistant enamel. I haven't painted my fiberglass under but I think I'd use the enamel would probably look better then the regular paint.
Old Apr 5, 2009 | 06:53 PM
I think my insulation is shot. I need to pull it down and replace it... RS.
Old Apr 5, 2009 | 06:59 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
id like to put that mirror finish look under mine. havent seen to maybe 3rd gens with it.. my older friend has a BESUATIFUL black 69 camaro with that mirror finish panel under his hood. love that stuff. very pricey though.
Old Apr 5, 2009 | 07:09 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
OK, so go to NAPA and get the reflective underhood insulation, I got the same on my El Camino. To remove the old insulation just pull off the old black insulation and the tabs. then use the shiny tape that comes with the reflective insulation and tape it to the under side of the hood. You can still use the tabs if you wish to better hold up the new insulation.
Old Apr 5, 2009 | 08:58 PM
You talked me into it RS. I'll check out the napa stuff. It might be the same as the 3m stuff you can get at a low's. You know, the stuff you wrap water heaters, and other hot stuff.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
