Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
3rd gen power steering help
Old Jun 8, 2009 | 09:03 AM
r-borgmi's Avatar
im having a hard time setting up my power steering pump on my 86 z/28 i have a stock 86 pump with no brackets. i am also running a 1970 350 block. i have checked with summit and jegs and nobody can help me out.
the old style 70 and up brackets will not work due to the power steering pulley hitting the gear box and i dont think the stock brackets will work with the old style 350 block. i just need the correct brackets.
i am running stock v belt setup on the pump with a long water pump and the pump is on the stock location (drivers side) any help would be great im getting very frustrated. thanks all
Old Jul 11, 2009 | 10:50 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: 3rd gen power steering help
Factory brackets will work just fine.
Old Jul 28, 2009 | 02:47 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I just installed an early 70's 350 in my 92 Camaro. I had a V6 so I couldn't use the original pump. I got a pump and brackets from a 70's Chevy pickup truck in a local junkyard and they bolted right up.
Have you tried a shorter belt? Maybe you just have too long a belt and its allowing the pump to swing out far enough to hit the steering gear?
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
reiderz iroc
Aug 13, 2015 04:57 PM
