Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
BlackTop King's goes Black & Gold
Old Feb 4, 2010 | 10:08 PM
  #51
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
Re: BlackTop King's goes Black & Gold
Up Next for the interior...Well newest items are the Autometer Gauges -
RPM MPH Volt Water Fuel Oil
I have some ideals for the mounting, but I am going need to do lil homework on wiring them in.
So if any one has any advice prior, please let me know-
I am not 100% sold on the chrome look trim, I may try to convert that to just Black - Reason is I am thinking of making a face plate to replace the stock gauge section-mounting the autometers in the same locations as stock but with a look simular to the 2nd gens. This will allow me to keep the Black and Gold theme on the inside as well. I will work on getting some type of pic of what I am thinking or at least as close as i can find.
Of course and thoughts are welcomed.
Also to add - I was able to get 1 G-Force 5point camlock harness in Black so i will need another. So let me know if any one might have one.
Just looking to see if i can get a set for less then JEGS
Old Jun 5, 2010 | 09:06 PM
  #52
Some UpDates
Still doing alot of work and still alot more to do- but it is coming to gether a litlle at a time...
Old Jun 5, 2010 | 09:18 PM
  #53
if anyone remembers i had a couple post about the gauges and a set up for the TA. well based off the design idea's this is what i ended up finally doing and i mean finally....i have had these gauges for ...what 3-4months now and still not in car...wtf.
either way i got to do a CAD drawing with the measurments and all- pluged it into the cnc (amanda) at my job- and Boom boom boom...
18g Stainless....
perfect fit....and the 4 smaller gauges, check out how close yet how well they fit...i was so proud of myself for this one...
I leveled them out higher so that the extra room (lower) could be used for something else...
Check it out
now i got to fig....do i keep the stainless look and make a piece for the center console and radio brazel to match (maybe other areas as well) or
my orignal idea...which was to mimic the gold look of the 2nd gen trans am's.....maybe a graphic wrap or something else...
only other ideas were to...
Paint Black
Carbon Fiber graphic wrap
not really sure, anythoughts
Old Jun 6, 2010 | 10:21 AM
  #54
jccaclimber's Avatar
Car: 1991 RS Camaro
Engine: 350 0.060" over
It's a flat surface, and I suspect you're decent with fiberglass, or know someone who is. Why use carbon wrap when you could use actual carbon?
Old Jun 7, 2010 | 08:03 PM
  #55
Well i have used fiberglass and am getting quit good at it- hopefully ill be able to make all kinds of stuff,
but i have never used carbon fiber !?!
so i would be lost with that.
Old Jun 7, 2010 | 08:42 PM
  #56
oscarsrs's Avatar
Car: 91 RS/ QX56/Altima 3.5 SE
Transmission: AUTO
Axle/Gears: ?
great seats ! if missed it am sorry but what car or were are they from ? who makes them , thanks
Old Jun 8, 2010 | 07:16 AM
  #57
Car: 1991 RS Camaro
It's pretty much the same but:
1) Try to keep the dust off you/your lungs as it's way worse than fiberglass dust, and it stays in you longer.
2) Try to keep your edges looking nice because it'll show if you have to sand lots of it (sometimes ok).
3) Don't use a really thick epoxy, and be sure to roll it in through the fabric.
4) A SMALL amount of sanding, and a clear coat works wonders.
Old Jun 12, 2010 | 12:10 AM
  #58
The Seats were from Jeggs
What Car?
and who makes them?
The seats? - They are from Jeggs I guess, thier brand- dont know, but i tell you what- great seats for the PRICE...
Really are
Old Jun 12, 2010 | 12:14 AM
  #59
Thanks for the Tips, I think what ill do is get a small amount and go from there- kind of play with it a bit and see how that goes.
I mean- if I got really good- alot of the TA would be...LOL
Is the resin and epoxy for fiberglass useble for the CF...
I mean I think I will google it and see what i can fine- but it be cool if i could use alot of the same (fiberglass and CF)
plus i agree- clear coat clear coat and more clear...
I have a set of CF flush hood pins - real CF too, but has no clear- and i hate it....so i will tryto clear em and post pics...
when i get that far... dont know if they will go on the car for say but got in case i like em enough to do so.
you know
Old Jun 12, 2010 | 08:44 AM
  #60
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
To make carbonfiber look good it needs to be vacuum formed (bagged) IMO. There are some tutorials around for it on the net and a ton of youtube vids. Mainthing about CF it's made to be strong and light so that's more or less what you're paying for. I've never tried to do it since I didn't want to make a jig to vacuum bag stuff.
I use to get all my fiberglassing supplies from http://uscomposites.com/ they sell Carbon Fiber stuff too.
Might be a lot easier just to slap a carbon fiber look a like decal over it. With your retro look the old prisms type decal might like look good too.
If you wanted to go more serious look they make Carbon Fiber look a like plastic. Found this post on another forum for a dash build that I'm a member of. http://www.pro-touring.com/forum/showthread.php?t=62487
Old Jun 13, 2010 | 01:04 PM
  #61
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Get the gauge panel engineturned- it will match the 'stock' look of the earlier firebirds...
Old Jun 13, 2010 | 08:25 PM
  #62
Thanks for the information and thoughts... i did think to get the decal CF for the look and because i could change it...(i like to do that for some odd reason) and so i can kind of see if i would want to go that route.
but not sure.
Old Jun 13, 2010 | 08:27 PM
  #63
That I would do in a heart beat, drop the rest of the idea's and go that direction.
I even hunted for like 2hours for a CF-Gold color either real decal...something....
found nothing at all close.
now even if i couldnt get the exact look of the second gens- that maybe even cool to get something LIKE...so i can still have the twist of difference....but havent found that either..
engineturned - that is the pattern ?
Old Jun 14, 2010 | 11:32 AM
  #64
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Quit repeatedly saying 77-79 turbo trans am.
There is NO 77-79 turbo trans am.
There is only an 80 and 81 TTA.
(which is actually what my 80TTA in my sig started life as)
Old Jun 15, 2010 | 06:05 PM
  #65
were in the hell did i say that one time!!! let alone repeatedly!!!
Old Jun 15, 2010 | 07:03 PM
  #66
Larry 89GTA's Avatar
Car: '89 GTA
Engine: 5.7 TPI
Axle/Gears: Stock 3.27
I've looked for this too, but haven't found anything. There's a guy in the 2nd Gen community (user RCOMBS on transamcountry.com) who refinishes the original TA dash bezels. I'm sure he could do the engine-turning (basically using a drill press with the appropriate grinding wheel) and apply the gold and clear paint. I'd love to do this with my '89 GTA, so I'd be very interested in whatever you come up with. In my case though, I'd need some kind of overlay for the factory dash and radio trim plate (and maybe the shifter plate too), since I don't have your custom aluminum dash.
Old Jun 15, 2010 | 07:39 PM
  #67
Aaron91RS's Avatar
Car: RS
Really??? Heck another guy even called you on it on the first page and your going to ask where you said it.
https://www.thirdgen.org/forums/post...48-post25.html
And.....The Hood, Up I did it....and changed it up- I dont know if i am going to leave it as is...or add the flat black look on the inside of the bird-simular to the twin turbo hood...
I kinda do, tho, the 77-78 turbo trans am's had a look like that and I kinda was trying to just blend different features in to this design plus add and minus somethings, i do know by doing this tho- i will make it more
and again here...
https://www.thirdgen.org/forums/post...01-post48.html
The hood was modled after the
77-79 Turbo Trans Am
This is were the ideal comes from and tryed to twist it a little bit to be my own
Old Jun 19, 2010 | 09:51 AM
  #68
and again here...
Correction Takin, NOTE on Year Refferance Correction.
Old Jul 2, 2010 | 01:55 AM
  #69
7-1-2010
Well this is the update of 6/26 weekend of heat and Trans Am's.
Did a ton of things, most little but the effect was great.
Biggest change was the rims. I ended up going with the Black Center-Black Lip and gold pinstrip.
Not gonna post all the DIY, but is short I removed all four tires and took the rims all the way to bare metal...Whoa!!! what a pain but way worth the look- I realise the paint will only add to the work the next time i change my mind- so hopefully i just get my Vett 10spokes before then...LOL
I will also like to note: this time- no rattle and tons of clear
Before....
Jet Black
full pic with rims on...just to see how it looked..
JetBlack with pinstrip
this pic shows just paint...no clear at this time!
After this point once i saw the first rim with the pinstrip effect i went all out...even wet sand and buff...although the Black had a nice gloss from the bare metal coming threw and the thriple thick clear coat really made a nice reflection- after wet sanding and buffing them out...i could see me! and the rims currently shine better then the rest of the car...so I will be waxing the TA this weekend something seriouse.
Next was the Rear hatch...wash,vac and re-painted all the panels...all of them, this time! again no rattle and clear...nice shine i think
lol
Old Jul 2, 2010 | 01:56 AM
  #70
Next Engine bay!!! had some time and money- so i started and have been little by little working on getting it better- not completely there but i pulled all the loom off- re loomed (black and some red) organized the wiring much better and re-routed most- I also clean up alot. Not done but big improvement for the lil time i have had in it so far...really want the heater hoses off the motor along with the ss lines...but another time.
before
after
Red white and blueberry fest....
And some today...pics...
over all, i am happy with the turn out!
Now on to the next
Old Jul 3, 2010 | 03:00 PM
  #71
TorqueWolf's Avatar
Car: 85 TA TTA clone
Engine: 355sbc (turbo planned)
Axle/Gears: 9 bolt rear disk
Wow Even have color matched broom handle props. Now thats detail
Old Jul 3, 2010 | 09:47 PM
  #72
I am not that cheap dude- PVC!
Old Jul 5, 2010 | 01:16 PM
  #73
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
awsome fab skills bird looks sick
Old Jul 8, 2010 | 12:30 AM
  #74
Old Jul 8, 2010 | 12:05 PM
  #75
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Engine turning- here is a pretty good tutorial from you tube that might help you. It is easy as long as you plan it out and take your time...
http://www.youtube.com/watch?v=jf5dqUIT-eo
Old Jul 8, 2010 | 11:54 PM
  #76
very cool, thanks!!!!!!
Old Aug 3, 2010 | 11:37 AM
  #77
So- stress….
So what to do?
Me I do anything else…lol, really though I needed a break from all that is going on so I deside to do some arts and crafts time…
Got 4th gen console-used Auto…?
1. Its all I had
2. Just to be different
4th Gen top console-Auto Style, Basically what I started with.
Removed the Trans Control-section, mapped it out- to make a switch location (window)
Made a Plexi glass piece to use for mounting
Then with a fine brush- painted on a lil bandit guy- so that the blue LED’s will Illuminate threw…
  #78
Flash makes pics look bad- but you get the ideal- painted gold and assemble
Test fit- console top Jet Balck and Cleared
Remove cross bars and insert boot
This is what it would look like….
Had I only been able t leave it alone….but I cant…want more?
Old Aug 3, 2010 | 11:38 AM
  #79
Desides to change the layout- want shifter up front and to pull console back and up- for a more dramatic flow.
Cut out remaining from mounts:
Make a template-ABS Plastic- cut to fit the gap and clean the console
Plastic Weld- and smoothed it out
Old trick…Melted it down- fill it in and plast it out….ohhhh
Also note- added top bar across
Now I am not the best airbrush in the world and I sure don’t like lil things…..but lets have some fun
Old Aug 3, 2010 | 11:39 AM
  #80
Spectrum White-base, Charcol n jet blacks outline, shadow n small details-Metalic Gold on top!-
Jet black on top (center of console out)-two shots of clear…could of did another, but figured not to incase I want to change it later-
Later today ill post pic of it in car
Old Aug 3, 2010 | 03:18 PM
  #81
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
niceeeeeee
Old Aug 3, 2010 | 05:09 PM
  #82
Awesome-X's Avatar
Car: 87 Camaro
Man that looks awesome!
Old Aug 3, 2010 | 11:06 PM
  #83
thanks guys
I have some twicking to do tonight- but there is more....Radio area is pretty wicked too...will post pic when done
Old Aug 4, 2010 | 09:30 PM
  #84
OK- did radio brazel this morning and...
Just got done the install- looks good i think- I made a new location and switch board i guess you can call it. Like to see if any one can guess what i used to make it from- lil cut n chop and heat bend...but looks like it was ment to be there.
I got all the LED for the console wired up and will have to post night pics once i get the camera back-left in car-
Old Aug 5, 2010 | 08:39 PM
  #85
Not sure were I am going with the recent sckull effects, but its turning out well and to be a lot of fun…
This is the NOS Bottle i did this afternoon as i awaited.
Old Aug 20, 2010 | 11:10 PM
  #86
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
I'm not a fan of skulls but your looks awesome. You sure are talented with your artwork. Great job!!!
Old Sep 9, 2010 | 11:54 PM
  #87
Almost complete...at about 95%
Alot is flip flopping on me in life personaly- so as i go with the flow-i have found my mental release to be quit extreme once it hits the car...although i have to say i have impressed my own self...looking wicked....
So I airbrushed the whole trans am at this point except the true black fire and flame effects that will burn off the nose-fade to faces over the T Tops and hit the rear... this is what i got done so far...
Hood: The Trans Am bird is re-done with a metalic and pearl gold- color shifts in light like flickering fire...sweet in the sun, added smoke and ghost faces with in the toned black and grim reaper on the pro street scoop.
Old Sep 9, 2010 | 11:55 PM
  #88
Pass Side: Reaper with grave yard- tumb stones- of dodge ford and chevy emblems-Gates and gold Rose...Ghost faces in Toned Black with in a trible cut threw out sides- almost cant see untill you walk the car...love em
Old Sep 9, 2010 | 11:57 PM
  #89
Driver side: reapers battle- evilish creature with ball n chain also with the same ghost face with in trible cut threw out sides...
  #90
Rear Hatch- Rear seat delete is just about done- now featuring and holding a full 2800watt system that screams...air brushed console-sails and rear seat delete box-sub box...
like i said- not to much to do...juts the nose t top and rear bumper- will be done tomorrow.
hopefully from this work- ill get a chance to do more and more...gonna push the new concept of
BlackTop Ink
Old Sep 10, 2010 | 01:30 AM
  #91
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Will all that wash off ?
Old Sep 10, 2010 | 08:47 AM
  #92
No, wont wash off at all in fact wash wax and more....its hoc paint....lol... will clear when done tho
Old Sep 11, 2010 | 09:08 PM
  #93
Rear Bumper finished with the angles...
Nose is finished...
Just the T-Tops and Spoiler to do...already started to clear the car...Nose Hood Doors and Front fenders are cleared. Removed to paint the back sides and clear all around. sharp looking i think
Old Sep 11, 2010 | 09:20 PM
  #94
ls1fiend's Avatar
Car: 1985 z28, 1994 Sierra
Engine: 350, 350
Transmission: T-5, 4L60E
So how do you like those Summit seats? It may have already been covered and I'm sorry if it has. I read this thread a while back and didn't feel like reading it again.
Old Sep 11, 2010 | 09:48 PM
  #95
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
lol i think he ment can you take it back off
Old Sep 12, 2010 | 11:10 AM
  #96
I actually really like them and for the price you cant beat it- they are snug fit but i have had no issues with fit ment and still re used stock tracks to not drill holes in my car...
Old Sep 12, 2010 | 11:13 AM
  #97
as far as removel....like anything else, i would wet sand it off if you wanted to remove it before clear for any reason...
kinda the best and ezest way... i mean airbrushing is not ment to have a lb of paint- so it is fairly eazy to change if you want....
i personally wanted to do it this way ( as in pics) but depeneding on the look design and style- it can and should be done other ways...
Old Sep 15, 2010 | 04:01 PM
  #98
ls1fiend's Avatar
Engine: 350, 350
You don't look very big, no offense. How big are you? I'm 6'1 or 2 and weigh about 235.
Old Sep 15, 2010 | 08:31 PM
  #99
bakes85's Avatar
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
ok, this may be a stupid Q, but are those like decals or what? because the bird looks sick.
also very nice job on the car, all the custom stuff is kickass. some of it isnt my style, but nobody can say that they have a car that looks as unique as that.
Old Sep 15, 2010 | 10:22 PM
  #100
No offence
I am 6'2" at 170 ish (wet) lol
Not a big dude, but seat- i would say- would fit ya, if you were close i say come test them...lol
As for the Car...
No,
No Stickers-No Stencils, all free hand all paint (airbrushed)
I have step by step pics of everything i did if interested...I can help ya out...
but if you really really look- you can see.
for example- the bird had to be done with one line...in order not to over lap or see strokes...
thing is, you can see in the thread i have used that same design bird 3-4 times on the hood...so honestly i have done this bird since i was 8-9yrs...i got it down packed...lol...love trans am's
thanks for the complaiment though...it is unique...and it seems to be my thing...either you love or hate it, not many are in between. so i am glad there are somethings you like...hopefully it gives you idea's
