Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Need Help ASAP! PLEASE!
Old Aug 4, 2009 | 09:11 AM
DacMan's Avatar
Hi everyone,
I made my own floor pans for my 83 camaro, and overlapped them (new over the old), so today I went to weld in the bottoms to the tops and had trouble, can I just leave them the way they are, or do I have to weld the bottom (or original pieces) to the tops (new pieces), if so, can I just cut the old pieces up to my new welds?
Thanks, DacMan
Old Aug 4, 2009 | 09:51 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Need Help ASAP! PLEASE!
you really need to do a lot more reading. there are lots of posts here that deal with what you are doing. they each add to your knowledge base. some are more engineering oriented talking about stress points, some are more hands on.
use the search button and go into the fabrication section.
good luck
Old Aug 4, 2009 | 11:38 AM
DacMan's Avatar
Look Tony,
I appreciate the advise, really I do, but I've been a part of many forums in my life, and I am aware of how they work. All I need to know is what I ask. I know how to install floor pans and how to prevent them from rusting, I just need to know what to do about the lap on the bottom. If you had simply answered my question in the time it took you to write that, then I would have my answer. I didn't find anything on what I'm asking, and I took a good hour looking for it.
Thanks, DacMan
Old Aug 4, 2009 | 12:22 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
are you talking about the overlap holding moisture and causing the new floorboards to rust? my intention is to use an underbody coating to prevent that. if it's a tight fit (if you're welding it, I assume it's a pretty close fit) it shouldn't be much of a problem.
Old Aug 4, 2009 | 01:29 PM
DacMan's Avatar
Thank you,
I appreciate it, that was my exact question.
DacMan
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
