Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
need help tryg to use a old bm mega shifter with parts form a stock shifter possible?
Old Oct 17, 2009 | 07:14 PM
onenastyirocz87's Avatar
Car: 1987 Iroc-z
Engine: 5.7 tpi
Transmission: 700r4 with trans-go shift kit
i have a used bm mega shifter and shift cable for a 700r4 i dont have the neutral safety switch or revesre light switch for the the bm mega shifter i was wondering if i could just use the neutral safety switch and revesre light switch of the stock shifter assmebly on the bm mega shifter
thank you
Old Oct 19, 2009 | 04:11 AM
churchofruss's Avatar
Car: 1987 chevy camaro
Engine: 350 roller/edelbrock/holley carb
Axle/Gears: 3:42 open diff
Re: need help tryg to use a old bm mega shifter with parts form a stock shifter possi
thank you
i would imagine that would work,with the right tools you can use any kind.you can always make one too,the setup isnt too complicated
Old Oct 19, 2009 | 12:53 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
i dont think thats gona work... the backup/neutral saftey switch on the stock shifter is LARGE and its black and LARGE lol. the B&M one coomes with 2 very small switches... and u have to wire it yourself (help from the instructions) also need to get the required relay.... but i wouldnt use the relay they recomend. I went through 2 of them where the car left me stranded and thats at 10$ a pop for the relay. i upgraded and went to a 30-40amp relay from a cold start kit i had laying around and its been flawless since.
the saftey/neutral switch have to bolt on to the shifter and uses a metal "bump" to activate the switch then the shifter is in the correct gear. u can not get the stock one to work. you will need the B&M shifter cable for that shifter... which u said u have. u will need the relay, switches, and mounting hardware. since yours is a camaro im not sure if u have to modify the stock console since u idk if u have the B&M megashifter console lid thing. i had to hack a good bit of my firebird one to get it to work, B&M states this in there instructions.
Old Oct 20, 2009 | 05:11 AM
what ive done in the past is just left out the n.s.s. & hardwire the reverse lights into a switch like on the t handle or something.i've had the misfortune of many auto gremlins getting me when i least expect it,so my foot is always on the brake when i start the motor.the cool thing about no n.s.s was if i stalled ,i would just have to hit the key.my 78 nova i had for some reason loved to either stall around 50(no clue) & the gas pedal loved to stick
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
theshackle
Mar 5, 2017 06:37 PM
NBrehm
Aug 25, 2015 11:49 PM
1nastygta
Aug 8, 2015 07:38 PM
