Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
rear disc swap
Old Nov 9, 2009 | 05:32 PM
camaro391z's Avatar
Car: 1987 iroc
Engine: 391 stroker
Transmission: th350
Axle/Gears: 10bolt/4:10
rear disc swap
i recently got a 4th gen rear given to me that i was told was orig out of a 94 ta..... i was told u can swap the 4th gen rear disc to a 3rd gen drum rear??? can anyone give me sum pointers??
Old Nov 9, 2009 | 05:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear disc swap
The swap from drum to disc isn't direct. You'll need to modify the axle flanges or buy a kit from Ed Miller. You'll also need a combination valve and e-brake cables. Check the following FAQ for more info about the swap:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Nov 9, 2009 | 05:57 PM
camaro391z's Avatar
Car: 1987 iroc
Engine: 391 stroker
Transmission: th350
Re: rear disc swap
ok thanks just wanted to make sure it was possible b4 i cut that top of the flange off. looks like the ebrake is inside the rotor, will my axles wrk with that setup?
Old Nov 9, 2009 | 06:16 PM
JamesC's Avatar
Re: rear disc swap
https://www.thirdgen.org/ls1reardisc
JamesC
Old Nov 9, 2009 | 06:26 PM
Stephen's Avatar
Car: 87 GTA
Re: rear disc swap
Just swap the entire rear end. WAY easier, free & a direct bolt-in.
Old Nov 9, 2009 | 06:30 PM
camaro391z's Avatar
Car: 1987 iroc
Engine: 391 stroker
Transmission: th350
Re: rear disc swap
yea that wld be the way to go but the housing was busted.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
