Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
fuel pump
Old Jan 31, 2010 | 01:37 PM
glmor86ta's Avatar
fuel pump
best way to cut a hole in the trunk to change the fuel pump
Old Jan 31, 2010 | 02:04 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: fuel pump
Cut off wheel... And cross your fingers theres no vapors. Or jig saw and hopefully you don't cut into your tank. I actually cut mine when I did my LS1 tank swap so I didnt have to worry about fire and changing at a later date.
Old Jan 31, 2010 | 05:08 PM
BPWilliams's Avatar
Re: fuel pump
Agree cut-off wheel with a full tank of gas. Gas liquid will not ignite like vapors will so it is best to have it full and go slow not heating up the whole area at once. The cut-off wheel is also great at making room to move the tank also!
Old Jan 31, 2010 | 06:26 PM
87_Injected's Avatar
Car: 2010 2LT RS
Re: fuel pump
Thats an interesting set up you have there. Any pics of it with the carpet installed etc..??
Old Jan 31, 2010 | 07:16 PM
glmor86ta's Avatar
Re: fuel pump
thanks for the reply
Old Jan 31, 2010 | 07:18 PM
BPWilliams's Avatar
Re: fuel pump
UMMM, Carpet? Sorry not that kind of car. I am sure it could be done with my set-up but this is track only 84 Camaro Z-28. I have a custom 3-link and needed the room above the Diff for the bracket, so i moved the fuel cell to the rear of the car for weight transfer. Then I welded in a basket for the fuel cell with strap hangers. The fuel pump and filter is mounted to the braces under the car, hard line to the front.
Old Jan 31, 2010 | 08:31 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: fuel pump
pull up the info under search ( fuel pump access hole). Anyway I used tin snips no chance of starting a fire.
Last edited by Dustytrix; Jan 31, 2010 at 09:22 PM. Reason: found thread listed different
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
