Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fuel cell install
Old Apr 28, 2010 | 02:50 AM
327sleeper88's Avatar
Car: 1988 rs
Engine: 555BBC; Dart, Lunati, SRP, Howards
Transmission: ATI TH-400
Axle/Gears: 35 spline 9", locker, 3.00's
Fuel cell install
I am looking to put a fuel cell in the luggage area in my camaro. i have done some searching, but it seams that a fuel cell isn't too common in third gen's. Also, i see that most often you end up butchering the rear area to fit cells like THESE. I don't need to hear that i should sump the factory tank, its not going to happen. besides, my factory tank is cracked and leaking around the filler neck.
Also, i am going to run 3.5" dual exhaust out the back of the car, so i need room to rout it over the axle.
i was looking at an RCI 15 gallon one HERE. i measured the well at about 31" by 12" at the bottom (because it is tapered). has anyone else used this fuel cell? it seams like the perfect fuel cell for a third gen!
Help appreciated!
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
colton_carlson
Mar 8, 2019 12:21 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
