Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
WELDING
Old May 8, 2010 | 09:50 PM
GI.JOE.Z28's Avatar
Car: 25 ANIVERSARY Z28
Transmission: AUTO
WELDING
HELLO I RECENTLY BRING TO MY HOME MY SECOND 3RD.GEN I FOUND THAT IS HAVE A CRACK IN THE CHASIS ABOUT 6 IN. AWAY FROM THE STIRING BOX!!! CAN SOME ONE TELL ME HOW TO FIX THAT? IF BE A PROPER WAY TO FIX THE CRACK!! THANK YOU! ATT. SGT. RAFAEL LEANDRY
Old May 8, 2010 | 09:52 PM
GI.JOE.Z28's Avatar
Transmission: AUTO
Re: WELDING
[quote=GI.JOE.Z28;4538392]HELLO I RECENTLY BRING TO MY HOME MY SECOND 3RD.GEN I FOUND THAT IS HAVE A CRACK IN THE CHASIS ABOUT 6 IN. AWAY FROM THE STIRING BOX!!! CAN SOME ONE TELL ME HOW TO FIX THAT? IF BE A PROPER WAY TO FIX THE CRACK!! THANK YOU! ATT. SGT. RAFAEL LEANDRY
Old May 8, 2010 | 09:59 PM
LT1swapper's Avatar
Re: WELDING
[QUOTE=GI.JOE.Z28;4538395]
If you could post a picture, it would be easier for people to help you.
Old May 8, 2010 | 10:09 PM
GI.JOE.Z28's Avatar
Transmission: AUTO
Re: WELDING
[QUOTE=LT1swapper;4538400]
TOMORROW I WILL !!! THANK YOU!!!
Old May 8, 2010 | 11:06 PM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
Re: WELDING
After you repair it, be sure to install a wonder bar.
Old May 8, 2010 | 11:10 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: WELDING
if everything is square and its just cracked weld the crack and then weld a plate on top of it extending couple inches beyond both sides of the crack to reinforce the frame rail, if you want it to look like it was never there then you will need to spend more time in it and weld the plate on the inside of the frame its easy but it takes more cutting and time but will look like nothing happened
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
LC2 TECH
Oct 13, 2015 11:53 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
