Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
modified gas tank
Old May 24, 2010 | 09:38 AM
mesterz2889's Avatar
modified gas tank
I have been reading and its seems like it would be a huge pain to get the 4th gen fuel gauge to work after swapping in a 4th gen tank. MY question is would it be possible to use the third gen pump in the 4th gen tank by cutting the pump mount from the 3rd gen and somehow attaching it to the new tank. I know that there would have to be steps taken to ensure that the tank wouldn't leak and would be pressure tested. what do you think?
Old May 24, 2010 | 10:12 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: modified gas tank
well if you can take the 3rd gen (metal) tank mount and adapt to the 4th gen (plastic) tank mount please post how as I've never seen it done.
Old May 24, 2010 | 05:40 PM
I know that they are made of different material. My plans were to cut the 3rd gen pump mount about 2 inches bigger than the actual pump hole and then make a same size ring which would go on the inside and bolt them together sandwiching the 4th gen tank between them. Make sense?
1fast91
Sep 8, 2015 01:48 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
