Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
My Custom Dash UPDATE (06-15-11)
Old May 5, 2011 | 12:41 PM
  #51
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: My Custom Dash Idea
Are you stil planning on using the LEDs?
Very interested to see the final piece. I planned going with something pretty similar to that design but using fiberglass and wooden mounting rings.
Old May 5, 2011 | 01:11 PM
  #52
Turbok9's Avatar
Car: 91 Z28 Coupe / 92 RS Vert
Engine: L31 350, HSR / L31350 Carb
Transmission: 700R4 / 700R4
looks great! My Grady White's cluster looks similar, 'cept it's a 2X3. Nice!!
Old May 5, 2011 | 01:49 PM
  #53
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Originally Posted by JeremyNYR
That's a nice looking layout. What's the rectangular section under the three small guages for?
The small rectangular area will be for auxiliary switches, like for my fog lights or something.
Old May 5, 2011 | 01:53 PM
  #54
fiream's Avatar
Engine: 400HP 350
Originally Posted by BlackenedBird
I like the 2x2 idea myself. Also like you said......Far right ones are out of the line of sight if they are straight across.
If you do them straight across, I'd put stuff like the gas gauge over there.
I ended up being able To fit three of the larger 2-5/8 inch gauge on the right which should be totally viewable, I hope...lol
Old May 5, 2011 | 01:56 PM
  #55
fiream's Avatar
Engine: 400HP 350
Yes I'm still going to use LEDs for turnsignal indicators and for a high beam indicator and whatever else is normally in the stock panel. Let me know if you want a copy of the .psd file this panel to help you with yours.
Old May 5, 2011 | 10:01 PM
  #56
fiream's Avatar
Engine: 400HP 350
Some pictures from today.
Old May 5, 2011 | 10:06 PM
  #57
Engine: 383 SBC
Very cool. Do it with a drill press or just hand drill?
Old May 5, 2011 | 10:13 PM
  #58
fiream's Avatar
Engine: 400HP 350
All done on my drill press, I picked up a circle cutter at Sears to make the holes. I'm still debating on "engine turning" the aluminum. I like the 2gen dash, thats why I wanna do that.
Old May 7, 2011 | 11:24 PM
  #59
fiream's Avatar
Engine: 400HP 350
My progress and test fitting for the day. What do you think?
Old May 7, 2011 | 11:27 PM
  #60
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
That looks really nice.
Old May 8, 2011 | 06:25 AM
  #61
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Thats flat? I liked the idea of it "pointing at the driver".
I am making my rally, really curved, more the C4 stock dashes.
Old May 8, 2011 | 08:05 AM
  #62
fiream's Avatar
Engine: 400HP 350
I mAy or may not leave it flat. The aluminum panel is pretty flexible, I could use a piece of mdf or plexiglass to prop up the passengerside to make it curve. I won't know this till I get it in the car. I'm
Also still undecided about what lights to use for indicators.
Old May 8, 2011 | 08:17 AM
  #63
Engine: 383 SBC
Summit carries warning lights and indicator lights in different sizes, but they are pricey $3-$9 each.
Old May 8, 2011 | 08:31 AM
  #64
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
How about cutting small arrow shapped holes, covering them with some kind of tinted foil and then putting leds behind that? Cut shapes would look awesome on aluminum.
Old May 8, 2011 | 09:48 AM
  #65
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Looks great, I always liked the 2nd gen dashes too. When I made my gauge panel I had it brushed and anodized black. Makes me wonder how yours would look anodized with the pattern you have in it.
Old May 8, 2011 | 10:51 PM
  #66
fiream's Avatar
Engine: 400HP 350
I made some progress tonight on the dash. I'll finish it up tomorrow after I finish putting the car back together with the new trans. Might post a vid, IDK, maybe..
Started at about 8pm with this:
Worked till midnight and i'm about halfway:
Old May 9, 2011 | 08:55 AM
  #67
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
looks great i wanna do somethiing like this for my camaro how much did those gauges run?
Old May 9, 2011 | 09:48 AM
  #68
fiream's Avatar
Engine: 400HP 350
The gauges ran about $700 from summit.
Old May 9, 2011 | 11:12 AM
  #69
h1-vltg's Avatar
Car: 91 Camaro Z28
Engine: LS3
Transmission: 6 Speed
Axle/Gears: 3.71
that looks really sweet!
Old May 9, 2011 | 12:16 PM
  #70
Engine: 383 SBC
You can usually get them a lot cheaper on eBay, but there used and most of them have dings in the rings or scratches on the faces. If that's the speedo it looks like it's the nice electric programmable one. I've never seen them really cheap on eBay. That's about the last one I need for my collection to start it in motion. I always thought it looked like a great idea being able to calibrate for tire swaps if you wanted to run some tall nittos one day instead of the normal street tires.
Old May 9, 2011 | 11:41 PM
  #71
fiream's Avatar
Engine: 400HP 350
Almost done with the panel. I worked on the car today and got it back on the road, didnt have time to test drive it today.
Old May 10, 2011 | 02:08 AM
  #72
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Looks like you've got the same thing I did - new, beautiful engine (tough I had all polished and chrome) with a lot of dirt on the outside Good that my blowned up so I get paint engine bay this time
Old May 10, 2011 | 09:10 AM
  #73
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I'm loving how the engine-turned pattern is looking! I'm a big fan of the 2nd gens as well. very nice work!
Old May 10, 2011 | 09:33 PM
  #74
fiream's Avatar
Engine: 400HP 350
okay so its all set, check it out!!! oh and a video of my car for y'all...
Old May 11, 2011 | 08:05 AM
  #75
JeremyNYR's Avatar
Car: 1984 Trans Am
that looks sweet! Can't wait to see it installed. How'd you go about getting that look? I've always wondered how that was done.
Old May 11, 2011 | 09:49 AM
  #76
Engine: 383 SBC
It's called engine turning. It can be done with hand drill or drill press. Drill press tends to make it more controlled and nicer pattern overall. You can adjust the swirls by the bit size used and how much you overlap. I've read articles about using wooden dowel rods works as a bit works too.
Old May 11, 2011 | 11:17 AM
  #77
JeremyNYR's Avatar
Car: 1984 Trans Am
i'm a bit confused. Do you put the bit in backwards or something to make it rub instead of cut through?
Old May 11, 2011 | 11:44 AM
  #78
Engine: 383 SBC
I know the wooden dowel methods I've seen use sandpaper. I would assume you could do the same with other bits if you loaded them backwards. I'm sure fiream can chime in on what he did.
Old May 11, 2011 | 06:50 PM
  #79
Yahtzee's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: 403 LSX
Transmission: TH400
Axle/Gears: Moser 9" 3.25's
COPYCAT!!!
jk
it looks good man!
Old May 12, 2011 | 09:14 AM
  #80
fiream's Avatar
Engine: 400HP 350
It's not really cutting anything, think about it as polishing a swirl into the metal. I'm a "Cratex" brand ruberized abrasive. It's almost like an eraser but sandpaper like. I'll make a short video showing how it works when I get home tonight.
Old May 12, 2011 | 01:30 PM
  #81
fiream's Avatar
Engine: 400HP 350
Here's a short vid
Old May 12, 2011 | 02:32 PM
  #82
JeremyNYR's Avatar
Car: 1984 Trans Am
Thanks for posting the video. That's a pretty interesting technique.
Old May 14, 2011 | 09:30 PM
  #83
fiream's Avatar
Engine: 400HP 350
Okay, who's ready too poop their pants?...LMAO!!!
Old May 14, 2011 | 10:57 PM
  #84
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Had a brain fart when I seen this thread come back up.
Would look cool to do the same thing but put all the smaller gauges in a cluter where the tach would go.
but what about the tach you say?
Get a Trans-AM hood tach
Best thing for racing, having the tach right in front of you in your line of sight, never having to look down.
Old May 14, 2011 | 11:30 PM
  #85
fiream's Avatar
Engine: 400HP 350
Yea i was thinking hood tach, but im short so the dash is in my whole line of sight, so it works out..lol
Old May 15, 2011 | 07:50 PM
  #86
fiream's Avatar
Engine: 400HP 350
Here we go, 90% done, I got all the lights I needed. Any suggestion? I was thinking about tinting it a little darkeror maybe painting the top above the upper bolts black maybe to break it up a bit, not so much silver. I dont know i'm so undecided..lol
Old May 16, 2011 | 05:54 AM
  #87
Engine: 383 SBC
Looks very nice to me. I'd just do the aux switch panel and install it. For wiring are you going to make your own connector to plug into the stock one in the dash?
Old May 16, 2011 | 07:48 AM
  #88
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
If you don't want it so "bright" (reflective), you could try putting on a layer of window tint. Something real light, not like 5%, not even 20&. Go find something like the stuff that is mainly used for UV ray block that is like 50% or 80% (i forget which it is).
Old May 29, 2011 | 09:37 AM
  #89
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
VERY COOL....
Old May 29, 2011 | 11:33 AM
  #90
83firechicken's Avatar
Car: 1983 firebird
Engine: 427 v8
Axle/Gears: 3.42 posi
how did you wire your led turn signal indicators , i am trying to do something veary smilar to this only with a second gen dash panal and i am not sure how to wire them but led's would be ideal for what i am doing
Old May 29, 2011 | 02:38 PM
  #91
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I think you'll find that with this configuration your right hand and part of the steering wheel will block these gauges. I know my right hand does in my GTA. Its a pain as I often have to move my head to read the 2nd gauge pod from the right. Very annoying.
Old May 30, 2011 | 10:05 PM
  #92
fiream's Avatar
Engine: 400HP 350
its pretty simple, the LED units themselves came from radio shack, i soldered wire on to them and then when the dash is in the car, i'll use quick splices to splice in to the factory harness for the power to the lights.
Old May 31, 2011 | 06:16 AM
  #93
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
great job so far fire arm, can't wait to see the finished installed product.
Old Jun 1, 2011 | 07:05 PM
  #94
fiream's Avatar
Engine: 400HP 350
So, I finished up the wiring for the lights today. I may have to get a very large resistor for the high beam indicator caus I think its going to be too bright even after nightshading it...lol What do you think? Light may look a bit croocked they're not tight in the dash, they're just sitting there...lol
Old Jun 1, 2011 | 07:16 PM
  #95
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
haha wow that would get annoying really quick if the high beam light was that bright.
Old Jun 8, 2011 | 10:04 PM
  #96
fiream's Avatar
Engine: 400HP 350
Re: My Custom Dash UPDATE (06-06-11)
UPDATE: (06-06-11)
Magnum opus
— n
A great work of art or literature, esp the greatest single work of an artist.
Okay so it 95% done, I got a few thing to finish up like the switch panel, and I have to decide which LEDs to use for Aux. lighting. Its pretty much done.
Old Jun 8, 2011 | 11:15 PM
  #97
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Looks good and is very reminiscent of the 70's T/A dash faces.
Old Jun 8, 2011 | 11:18 PM
  #98
fiream's Avatar
Engine: 400HP 350
Exactly what I was going for!!!
Old Jun 9, 2011 | 04:12 AM
  #99
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Looks good....
What are the red LED's by the water & volts for? Warning lights?
Old Jun 9, 2011 | 09:48 AM
  #100
fiream's Avatar
Engine: 400HP 350
Originally Posted by Primetime91
Looks good....
Yes, the one over the volts gauge will be hooked up to the factory battery light, and then the one over the water temp will be hooked up to the factory brake light. All the lights will have removable spades at the end so if I need to change one to lets say a water temp light i'll be able to do that.
