Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
NEW FMIC Intercooler Radiator done
Old Jun 23, 2010 | 01:00 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
One of the things I've done this year is a new IC/radiator setup
Old Procharger 3-core setup
Picture of new radiator and new Intercooler also will fit the AC condensor and a trannycooler between them
New lower radiator support
Old Jun 23, 2010 | 01:01 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: NEW FMIC Intercooler Radiator done
Testing
You can se the radiator is moved forward to give me more clearence with 12-rib setup and fans.
Painted
Airscoop mounted
The hood locking device would go right down in the IC so I had to adjust the hole with a hammer and bend the hook backwards, also made a protection plate for the IC.
Car is started some small issues left before testdrive……….
http://www.youtube.com/watch?v=RXGIGVI2HEU
Old Jun 23, 2010 | 01:18 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Looks well done, sure you don't want to add a scoop to the front to draw in more air or you think the air dam will be enough?
Old Jun 23, 2010 | 02:04 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Will see....
I can add a xtra scoop fastened inn the lower bolts for the IC....
I've also thinking of cutting a hole in the front but havent seen anything that looks nice, would also like to keeo the sleeper look
Old Jun 23, 2010 | 02:33 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
where can i find a Airscoop similar to that?
Old Jun 23, 2010 | 03:11 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
custom made
sheachopper
Jul 31, 2019 11:27 AM
lanceflame44
Sep 25, 2015 12:28 PM
