Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Removable Transmission Tunnel
Old Jan 5, 2011 | 12:30 PM
Warrior's Avatar
Car: 98 Camaro/85 Camaro
Engine: 3.8L/ 355 CI
Transmission: Auto/ TH350
Axle/Gears: 3.23 Posi
Thinking about doing it to mine as a winter project. Not sure if I want to cut and reuse the stock flooring or buy a universal aluminum tunnel. So who has a removable transmission tunnel in their car? How'd you go about doing it? Lets see some pics!
Old Jan 5, 2011 | 04:55 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Removable Transmission Tunnel
Short of a full blown track car, why would you want this?
Old Jan 5, 2011 | 07:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Maybe he needs to change converters several times a month
Old Jan 5, 2011 | 09:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I don't even have one. The only reason I'd like to have one is because I need to pull my tranny at least every 3 years just to replace the SFI dated flexplate. The tranny/flexplate shield is good for 5 years.
Having a removable tunnel just makes access to the bellhousing bolts much easier. With the shields and the engine pushed back to the firewall, access from the top for the bellhousing bolts is zero.
My tranny tunnel has been modified to allow a little more room. The front part has been cut out and a larger section added but it's still not removable.
Old Jan 6, 2011 | 06:21 AM
Warrior's Avatar
Yea it is in the workings of being a full blown track car. The car will not see the street.
And in the last year I have had the motor out once and tranny out twice for different reasons. Now I am about to pull the motor out again. And during these, I have always been unsuccessful at getting the top bellhousing allen bolts out from the top. They are a huge pain from underneath. Plus I am planning on putting in a flexplate and tranny shield when the motor goes back in.
So I figure, instead of fighting with it at least two more times this year why not put in a removable tunnel while the car is sitting and im itching to work on it.
Old Jan 6, 2011 | 12:17 PM
xpndbl3's Avatar
Car: 1984 Z28
why are your top bolts allen head and not a normal head? Also ARP makes some bolts with even smaller wrenches being used, I've never had a problem reaching mine from the top for the top 2. Mark the firewall and hammer that area a little for clearance if needed. Heck I moved my motor back 3/4" and still do the top 2 from the top.
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
