Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
subframe connector
Old Jun 23, 2011 | 08:50 PM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
Axle/Gears: 9 inch 3.25/4.11,axles moser 31 spl
subframe connector
hello
speak little English
look and advise my subframe
right or wrong
later install add ladder bars
Old Jun 24, 2011 | 02:05 PM
87CamaroIrocZ's Avatar
Car: 87 IROC
Re: subframe connector
too much air gap between tubing and body.Some places look like there is 1/8'' to 1/4'' gap that's a lot of weld to fill in. Fittment is the key to sound welds and a stiff body and winning races. grind, modify, and cut until the it fits perfectly do it right the first time or u will be doing it again when welds break I would weld it full length too just weld 6'' at a time and be careful not to burn through the thin underbody panels
Old Jun 24, 2011 | 05:36 PM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
if much remains to be welded
before welding and finish
I wanted the opinion of you is very important
thank you 87CamaroIrocZ
Old Jun 24, 2011 | 05:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you look to be on the right track. i would suggest welding a flat plate on the ends where you will be welding to the cars structure. the sheetmetal of the subframes is rather thin, and the added plate will provide more surface area to weld to the subframes, and add more strength.
Old Jun 24, 2011 | 05:54 PM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
I want to do something like this
I'm doing well or poorly
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
