Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
pros & cons of aftermarket TAs and ladder bars
Old Dec 21, 2011 | 09:41 AM
inled17's Avatar
I'm in the process of putting a new rear end in my camaro and was wondering how everyone's experience with them was. I will be putting coil overs on also
Old Dec 21, 2011 | 04:57 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: pros & cons of aftermarket TAs and ladder bars
im guessing TA is for tourque arm? if so ive got a sphon adjustable trans xmember mounted one and love it. and by ladder bars, to you mean lower control arms?
dont think this blongs in the fab section though, needs to be in the product review section.
Old Dec 21, 2011 | 05:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If your new rear end is going to installed with ladder bars then you won't need a torque arm or Lower Control Arms but will need to do a bunch of floor fabrication work to install ladder bars.
An aftermarket torque arm and LCA offer more stiffness and adjustability over OEM components. Poly bushings are much better over soft and squishy factory rubber bushings. Rod ends are even better but are noisy for street use and wear out faster.
Cons to aftermarket components? Price.
Old Dec 21, 2011 | 05:24 PM
travis401's Avatar
Car: 91 Camaro RS
absolutely true.
Old Dec 21, 2011 | 11:05 PM
inled17's Avatar
My motor is around 570 hp and i want to get nos if i can get it to hook up good and was more wondering if a adjustable torque arm and lca's would work good
F.I. 57 Belair
Aug 23, 2021 01:09 AM
J-money
Jan 4, 2019 09:45 AM
87camaro87
Sep 9, 2015 10:29 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
scotrans am
Sep 5, 2015 04:26 AM
