Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
sumped my stock tank now what with exhaust?
Old Dec 25, 2011 | 12:54 PM
roc_racer's Avatar
Car: 1985 IROC
Engine: 305 for now
Transmission: 700-R4
Axle/Gears: 3.73 w/ auburn posi
I just welded in a competion engineering sump into my stock tank. The other alternative was a fuel cell and i didnt like that idea. Im gonna run a holley blue pump with a return line to the tank. My question is now that ive sumped it the muffler is gonna be real close to the sump. Any body run into this problem before and what did you do? I could tilt the muffler a little but not sure if the inlet and outlet pipes will hit with a stock style muffler. I havent decided what exhaust to use so im not limited there. thanks
Old Dec 25, 2011 | 01:51 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: sumped my stock tank now what with exhaust?
99% of people dump the exhaust at their rear axle with a sump. Or put the factory heat shield back on I suppose and put heat shield wrapping around the fuel lines. They sell nice pieces that go over electrical wires with velcro on one side that would work out great for this.
Old Dec 25, 2011 | 02:42 PM
roc_racer's Avatar
Car: 1985 IROC
Engine: 305 for now
i can make a new heat shield or modify mine. The fuel lines arent gonna be an issue either. Ive looked at lots of pics of exhaust and i guess you would have to run true duals or a bullet style muffler right? I have hedman headers and y-pipe 2 1/2". Will it sound awful with a single 3" pipe with a single muffler dumped? thanks
Old Dec 25, 2011 | 03:59 PM
xpndbl3's Avatar
Car: 1984 Z28
no it would be fine that way too, lots of guys run a single pipe and one muffler with a turndown. Lots of the oval case mufflers are great for this idea.
Old Dec 26, 2011 | 09:19 AM
roc_racer's Avatar
Car: 1985 IROC
Engine: 305 for now
great info bud thats what im gonna try. Those mufflers are cheap so if it sounds funny i can change it and wont be out much. thanks
Old Dec 29, 2011 | 02:34 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Or you can run a setup similar to the SLP Loudmouth with the muffler before the axle then Y off to dual tail pipes.
Old Dec 29, 2011 | 10:06 PM
roc_racer's Avatar
Car: 1985 IROC
Engine: 305 for now
thats a option. But i just got in my dynomax and im gonna try it. maybe it wont sound retarded. lol I just bought a mid 80s 350 so i might be changing to a true dual exhaust anyway before long. Thanks for the input.
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
