Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
how much should a suspension upgrade cost?
Old Aug 6, 2012 | 02:40 AM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
I own a 1991 Camaro RS, dunno if it matters but its a 305 V8, it has the stock suspension, just its getting bad, i know i need a new a arm, pitmans, all that good stuff. i need bushings, struts, might as well replace the springs too. Anyone have any idea on how much it would cost for a full suspension upgrade?
Old Aug 6, 2012 | 03:20 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
Re: how much should a suspension upgrade cost?
do a search on it, its everywhere.
Old Aug 6, 2012 | 05:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Labor costs excluded, replacing al the steering wear parts will cost a couple hundred in materials, and go with good quality stuff, moog or equivilent. Spring kits are anywhere from 2 to 3 hundred depending on what they are, stock or drop. Shocks and struts are a different stock. You can go bwith a cheap basic replacement which will do well in a daily car for a little over a hundred or so for all four, or and they go up from there to the koni/bilsteins which are toward the top of the overcounter performance line at around 7 8 hundred for all four.
Depends on your budget and if you are doing work yourself. Labor cost at a shop will be more that the cost of the parts, especially if you do springs and bushings.
Old Aug 23, 2012 | 02:28 PM
nheller76's Avatar
Car: 89 RS Camaro
Engine: Original 2.8 v6 convert to 5.7
Transmission: Th400
Axle/Gears: I think its the 3.42
You can always pull your A arm out and have a shop press in the new A arm bushings in. I got mine put in at a little shop he also put in New moog ball joints and cleaned it up for 25$ an arm. It was worth not having to fight with the stupid thing.
J-money
Jan 4, 2019 09:45 AM
angel2794
Sep 8, 2015 06:22 PM
84 TA NV
Sep 6, 2015 08:02 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
