Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Putting custom square gauges into firebird dash.
Old Feb 10, 2013 | 02:15 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
so i've removed the AC vents from the center of the firebird gauge bezel. The car is becoming a race car so all the air components have been deleted.
The dimensions of the 2 holes are 3.5 in wide by 2.25 in tall. If i cut out that middle bar then the dimensions of the one hole is 3.5 in wide by 4.75 in tall.
i need opinions on who makes square digital gauges to fit these holes. Im looking to add either fuel pressure, engine vacuum, transmission temp, or oil temp. Maybe possibly a clock. If i cant find gauges to fit these holes then i will just make it a storage compartment. Any opinions on what to do?
Old Feb 10, 2013 | 02:16 PM
Twin_Turbo's Avatar
Re: Putting custom square gauges into firebird dash.
race car? then put a switch panel there
Old Feb 10, 2013 | 02:24 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
well street, strip, autocross car to be specific. and i don't like the look of a bunch of switches on the dash. id like it to look somewhat factory. i might just try 2 small circular gauges on a custom made panel but id rather find some square gauges
Old Feb 11, 2013 | 12:19 AM
BigKeg's Avatar
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
What kind of engine are you going to have ??? Just a carb or fuel injection ??? If yor going with fuel injection. ..you could put the programmer in that spot or a G-teck...
Old Feb 11, 2013 | 07:16 AM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
carb. just ripped out the ecm yesterday
Old Feb 11, 2013 | 12:37 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
I would just make some panels from ABS, bond it to the back, drill the 2-1/16" hole and install some standard guages. Like you were saying.. Youre other guages will be round, so might as well keep em round.
As to your question though...Im not sure who makes square gauges. I dont think Ive ever seen them, unless you get something digital like a scan gauge or something.
J.
Old Feb 14, 2013 | 02:32 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Not much time to look at gauges while autocrossing.
Just fill them with plastic as suggested.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
justin57
Aug 20, 2015 07:05 PM
