Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
T-Top Glass Removal! TA DA!!!! DONE!!!
Old Mar 30, 2013 | 03:34 PM
maule6's Avatar
Car: 92 RS Camaro T-Top
Engine: 305 V8
Transmission: 5 speed manual
Axle/Gears: stock
I bought my 92 Camaro T-Top a few weeks ago . It had the Plexy tops (Ugly as hell!!) So I bought a nice set of glass tops and of course, being from an 86 camaro, they had the small pins. so for the time being I just drilled larger holes and transferred the large pin mechanisms over. After I had both the glass tops installed I started looking at the Plexy tops and after a few different ideahs I came up with this and pulled the housing away from the glass no problem . Make sure the glass/Plexy is well covered with preferably very thick paper or like a Lucky Charms box taped into place leaving about 1/8-1/4 away from the glue. Take a thin flexable 1'' wide putty knife and sharpen it as sharp as you can. Start from the sides were the pins exit the holes (Yes it does seem barbaric but) hit it with a hammer untill about 1''-1 1/4'' of the putty knife is under the glue. After you have finnished with both sides start in the middle and work your way out to the sides. the putty knife will go in about 1'' and stop. (NOTE! Do the 2 small tabs on the inside last... It's easier lol) After you have cut through all of that take a smaller 1/8'' wide flathead screw driver to the very far end were the glass meets the outside trim and Carefully separate the 2 pieces. And if you have done this with care you will have 2 good pieces to clean a lot of glue off of .
Old Mar 30, 2013 | 04:01 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: T-Top Glass Removal! TA DA!!!! DONE!!!
Sounds good! Did you find time to take some pics?
Old Mar 30, 2013 | 04:26 PM
maule6's Avatar
Engine: 305 V8
Axle/Gears: stock
Unfortunately i did not get picks of the process for the first set. But here are the picks of the first set done. I will have picks of the second sets process hopefully by the end of this week.
Attached Thumbnails T-Top Glass Removal! TA DA!!!! DONE!!!-033013152056-1-.jpg   T-Top Glass Removal! TA DA!!!! DONE!!!-033013152225-1-.jpg
Old Mar 30, 2013 | 04:45 PM
thomas1976's Avatar
Car: 91 Trans am
Please make a nice write-up on the secont top, this is wery interesting!
TheExaminer
Sep 6, 2015 11:40 PM
RyanJB
Sep 2, 2015 01:27 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
