Rear Bumper Alum Replacement
Car: 1982 Firebird T/A
Im about to take off my rear bumper and take some aluminum square frames from work and fab one up for weight reduction. my question is that if the rear bumper provides any "stability" for the subframe that it will want to flex? Good idea or band idea?
Re: Rear Bumper Alum Replacement
I'm guessing you mean the metal part. Let me preface this by saying I'm no expert and I assume no liability if you replace this part, but I would say in terms of providing stability to the unibody subframes I would say no, that piece probably has very little impact on keeping the subframes plumb and square.
However, in an accident I would say that even in the 80's, they probably engineered certain aspects impacting crumple zones and such. My concern would be the thickness of the aluminum you're using and also what you plan on using to fasten this piece. Aluminum isn't going to have the tensile strength of steel and while you're fine for daily driving, in an actual accident, that piece could fail quicker than a steel section. That is assuming your steel piece is in good shape and not rusted around the bolt holes. The aircraft industry has certain standards for fastening and material thickness when using aluminum. I would say researching those would be a good place to start if you're set on this course.
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Take measurements and have a 1 5/8ths chromoly tube bent up. You can even make it a bolt in deal with the 4 holes on each side. It will be light and have very good strength. I have done it to mine and it supports the rear cover well. The only thing I had to do was zip tie the bottom up so it doesn't flap around.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
GM made an aluminum version of the front bumper.Some early 3rd gens have em, mine does.No rr version though.
There was/is a member here who made a tubular steel rr bumper many years back. JERRYWHO i think is the user name.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I made mine both front and rear with 1/2 inch aluminum channel stock and it has done a great job for the last few years and heavy abuse. With the rear unbolted it doesn'ts make much difference but I rode around for a day with the front crash bar disconnected and the car felt like a wet noddle in the corners.
Car: '89 IROC-Z
Engine: LSx
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
