Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Heater/AC delete panel??
Old Dec 2, 2013 | 06:54 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
I'm curious if anyone has fabbed a plate to cover that big ugly hole in the firewall left behind from removing a heater/ac system.
Old Dec 2, 2013 | 09:05 PM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
Re: Heater/AC delete panel??
I've seen a few guys use the fiberglass ones you can buy from hawks. Haven't really seen any creative fab work done with this. Get some template paper and start tracing and trimming. That's what I plan on doing
Old Dec 3, 2013 | 07:52 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I got one of these on ebay works great.
http://www.ebay.com/itm/82-92-CAMARO-FIREBIRD-HEATER-A-C-DELETE-PANEL-/150818293882?pt=Motors_Car_Truck_Parts_Accessories&hash=item231d78887a&vxp=mtr
Old Dec 3, 2013 | 10:14 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Fabirglass firewall panel would not be nhra legal.
I was going to suggest the aluminum one on eBay as well.
As for fabbing, it doesn't get much easyier than this one. It's just a flat panel.
Old Dec 3, 2013 | 11:08 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I found it easier to do two pieces. Less angles to cut. Plus the round hole has a lip so I did a square and did little bends on the corners so it would seal the hole and sit flat on the firewall.
Night rider327
Oct 9, 2015 09:25 AM
djmarch
Oct 2, 2015 10:41 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
