Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Billet parts that you wish were made for 3rd gens
Old Mar 18, 2014 | 01:25 PM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
Axle/Gears: 3.42 Posi
Just got a CNC for doing small batches and custom one off pieces.
What are some pieces that you wish were made for these cars but are not?
Post up your suggestions.
-Jared
Old Mar 21, 2014 | 12:08 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: Billet parts that you wish were made for 3rd gens
Front strut caps: headlight bezels: door handles- inside and out: shifter plate: pedal covers: hood hinges!(god, will someone come up with 3rd gen ones like Eddie Motorsports does for the 2nd gen???): interior door panel that holds the door handle, lock switch etc!
About all I can think of off the top of my head.
Old Mar 21, 2014 | 07:34 AM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
I was going to do the shifter plate fory car. I can't do the door hinges because if I rember right they are spot welded onto the doors and bolted to the body. I never gave the strut caps a thought. I will look into what I can do I am currently looking for this to practice with.
Old Mar 21, 2014 | 08:21 AM
LX_SS's Avatar
Car: 85 Firebird C&C T-Top
Engine: 347ci LS1
Transmission: 4L60E LS1
Axle/Gears: BW 9 Bolt Posi,3.27,C5+VE Brakes
If you want a good product to spend time on getting right and one that is in demand, look at bonnet hinges, im guessing aluminum flat bar, 1/2" would do the base plate/arms, then maybe requiring 25mm for the upper plate, unless your keen to weld (and can do high quality tig welding) you could make the upper plates out of 1/2" as well, then machine the corners to suit the angle you require to match the bonnet which you can then connect the 2 together , clamp it up, and weld it.
Just an idea anyway, well one of many that you could do.
Old Mar 22, 2014 | 10:48 AM
ajh87iroc's Avatar
Car: 1987 Iroc-Z
Engine: SD360 350 Vortec
Yes, Hood Hinges!!!
Old Mar 22, 2014 | 11:57 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I think it would be cool to do a billet pedal set, but make sure that the gas pedal is spaced up about .25-.5 inches from stock so that we can properly heel-toe.You could probably do it with little machined standoff spacers that sandwich between the stock pedal and the billet pedal. A lot of people just use a bunch of washers but I dont like that idea that much.
Old Mar 23, 2014 | 07:52 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
The iroc louvers functional that are billet would be worth it.
Old Mar 24, 2014 | 01:41 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
I like the strut tower cap idea micktroup2 thought up.
Old Mar 24, 2014 | 04:58 PM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
Ok, Sorry for taking so long to respond. I have looked into the hood hinges it maybe possible however I am not sure how durable they would be. I will need to look more into them this weekend. I am currently not able to look at mine. I believe that the pedal set will not be to bad to do. I was even contemplating doing a set for my car.
Another thing that I was thinking was the front supports that connect the K-member to the front horns. Another thing that I was thinking was spacers for the struts for the guys that are using washers.
That is all I can think of right now.
Old Mar 24, 2014 | 09:57 PM
Car: 1992 Camaro RS
This is the pedal setup I was referring to. Obviously it would be better out of aluminum. Probably too expensie for me to afford and too expensive for you to make, though.
You may want to make a few batches of RS and Z28 rocker/bumper emblems since the repros currently available are said to be pretty awful quality.
Old Mar 25, 2014 | 07:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
MBA used to fab billet pedals. Recommended.
JamesC
Attached Thumbnails Billet parts that you wish were made for 3rd gens-screen-shot-2014-03
Old Mar 25, 2014 | 07:40 AM
LX_SS's Avatar
Engine: 347ci LS1
would a cheaper option for the pedal be to remake the rod that the assembly sits on to reposition it where you need it, rather than making a bulky spacer ?
Old Mar 25, 2014 | 07:06 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
People want Hinges like the last batch They were offered here on.
Very Sturdy of done right.
Attached Thumbnails Billet parts that you wish were made for 3rd gens-blkshock1.jpg   Billet parts that you wish were made for 3rd gens-polishedhinge.jpg   Billet parts that you wish were made for 3rd gens-ph3.jpg
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Few more..
Attached Thumbnails Billet parts that you wish were made for 3rd gens-hood1-1.jpg   Billet parts that you wish were made for 3rd gens-blkshock1.jpg
Old Mar 25, 2014 | 07:43 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
Those look good, but are they lighter than the stock hood hinges?
Old Mar 25, 2014 | 08:36 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Its not always about being lighter. Some want a Nicer , better quality part.
You want lighter & nicer bust out the check book and I can get them made out of Titanium.
Old Mar 25, 2014 | 10:20 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Originally Posted by FSTFBDY
Few more..
Those look great!
Old Mar 26, 2014 | 01:40 PM
BADNBLK's Avatar
COTM Editor
I have one those billet hood hinge sets! Love them. Weight is pretty close to stock hinges.
Think the dude made two, the polished ones, and the brushed finished ones that are pictured on the car. Can't imagine these could be made cheap enough that most would be willing to pay for them.
I think making up a pedal set like the MBA ones posted is a great idea. I love my MBA pedals, and think others would appreciate the high quality feel.
Old Mar 26, 2014 | 01:54 PM
JamesC's Avatar
Billet fuel door.
JamesC
Old Mar 26, 2014 | 04:34 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
[QUOTE=BADNBLK;5737386]I have one those billet hood hinge sets! Love them. Weight is pretty close to stock hinges.
Price is why I never went and did any hood hinges Like You said couldnt be done cheap enough to make it worth anyones times.
Originally Posted by JamesC
Billet fuel door.
JamesC
You do know the mustang bullet billet one fits our car with very minimal mods. Its been talked about on here before also.
Old Mar 26, 2014 | 05:49 PM
JamesC's Avatar
[QUOTE=FSTFBDY;5737490]
Yes, I've seen the threads, but I prefer something designed specifically for our cars.
JamesC
Old Mar 27, 2014 | 11:46 AM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
I do not think I will end up doing the hinges. However I will more than likely be doing a set of the pedals.
Old Mar 27, 2014 | 02:15 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Few more..
Cash is KIng!.. as long as they fit and work..will $500 buy me a set?
Let me know...and send me paypal info....
Old Mar 27, 2014 | 07:41 PM
Car: 1992 Camaro RS
Just check out what other sites charge for them. They tend to sell for around $100. More for more exotic surfaces on them. Make sure you can do it and be competitive.
The main thing is I want pedals that set the gas pedal MUCH farther forward than stock (never considered bending that rod..... but probably around .25 to .5 inches if I had to guess) and that the gas pedal is smooth while the brake and clutch pedal are not. Or I can put some skateboard grip tape on them or something. Not a big deal. As long as the gas pedal is smooth. (For heel-toe)
But I've had so much bad luck the last few months I cant afford to buy any car stuff right now. Between the fuel pump issues and problems with my daily and other crap that keeps coming up it will have to wait.
Old Apr 1, 2014 | 06:42 PM
nobodys got them for sale...even putting up $500 to start..
Old Apr 10, 2014 | 07:56 PM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
How about some under the hood stuff like radiator shroud, alternator cover, coolant and washer fluid tanks, you know, just dress up parts that are affordable for the average working man.
Old Apr 10, 2014 | 08:43 PM
IROCUDREW's Avatar
Car: 1989 Chevorolet Iroc-z convertible
Engine: 383, holley terminator efi
Axle/Gears: stock 10 bolt w/ 3.73
Deleted.
Old Apr 11, 2014 | 01:56 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
A gauge holder that mounts three, two inch gauges right below the center A/C vent. You could make a single or double gauge holder also but three would look semetric and about the same width as the vent. A custom overhead console could be interesting also.
Old Apr 11, 2014 | 02:19 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
What would it cost to have a custom bumper badge to replace the old "TUNED PORT INJECTION" with "TURBO 3800 SERIES II"
Old Apr 11, 2014 | 10:51 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Or a set of V6 badges with the GN symbol for the 6?
That would be badass. Those hinges look amazing though.
Old Apr 15, 2014 | 02:00 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Depending on the price I would be down for two sets of hood hinges if they had sealed bearings for all the pivot points. I would be down for one set for sure though $500 would be a good deal for one set, a little less and I may be able to buy two
Old Apr 15, 2014 | 08:56 PM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
I believe FSTFBDY is making a lot of the badges already.
We finally had a first training session on the machine yesterday, ended up engraving both of our vices afterwords. I will be home more often come the middle of May and I plan on taking on the pedals and doing a center gauge setup for 2" gauges and also the 2 5/8" and some switches. I may also do a radio delete panel.
Old Apr 15, 2014 | 09:58 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Yes, I do custom emblems on a personal needed order.
I can get The Hood hinges done. Just need to sit down and blue print em. Ive talked to a buddy of mine who Owns a shop who can do 10 sets minimum if We do make em.
Old Apr 15, 2014 | 11:37 PM
im in for a set...so thats 1 set
Old Apr 16, 2014 | 01:25 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Ive had a few Interests via PM also.
Just gotta find the Time to make a blue print or someone to do it before I get the time to do it.
Old Apr 16, 2014 | 02:00 PM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
Email sent.
I will also be doing a center console plate (Manual) for my car so if anyone would be interested send me a PM.
Old Apr 16, 2014 | 07:21 PM
one92rs's Avatar
Car: SOLD!!!!!
another vote for the strut tower covers
Old Apr 16, 2014 | 07:25 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
covers? or the complete strut top mount? I think the complete aluminum ones like mine would be a hot ticket. At the right price. Might be a hard one to compete with all the others out there. (they just arnt aluminum)
Old Apr 16, 2014 | 08:39 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I'll add another vote for the strut caps. How about a round shift **** with either a firebird or camaro logo engraved on it?
K n o b is not allowed??
Old Apr 16, 2014 | 10:14 PM
willexoIX's Avatar
Ill second the shifter ****, great idea 92rs!
Old Apr 17, 2014 | 11:35 AM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
shifter ****, ebrake handle, gauge rings, strut towers are badass, as the hinges, id say things like rad covers but people do so many different things thatd be hard to mass produce
Old Apr 19, 2014 | 09:38 AM
  #42
neilb's Avatar
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Front spindles!!! ones that accept the LS1 brakes or better with the corvette c5 hub assemblies and improved steering geometry. Just bolt in a go!!
Old Apr 21, 2014 | 07:10 PM
  #43
one92rs's Avatar
Car: SOLD!!!!!
how much for a set of those strut tower covers
Old May 16, 2014 | 03:34 PM
  #44
BADNBLK's Avatar
COTM Editor
Old May 16, 2014 | 04:28 PM
  #45
Nobody as come forward with a set for sale yet. No worries when it comes time to contact me and you got them...cash is king.....
Just tryin to score any out there...even if I buy 2 or 3 sets....do you really think I would get stuck with them ?......
Ill post a few pics to night of my over spending and upgrading parts before I even install what I have....its going to be a good yard sale....when the cars done
Old May 16, 2014 | 05:57 PM
  #46
spencerific93's Avatar
Car: 1986 Chevy Camaro IROC-Z28 (t-tops)
Engine: 305ci TPI (LB9), 150K miles
Transmission: Auto 4-speed with OD
Axle/Gears: Stock - 9.5 posi
Louver headlight covers? I know they made them at some point, but they are hard to find.
Old May 17, 2014 | 09:54 PM
  #47
AssaulT/A's Avatar
Car: 1986 Trans Am
Axle/Gears: 3.08? unlimited slip
How about a vertically oriented pistol grip shifter handle with "Trans Am" engraved on the sides?
Old May 19, 2014 | 05:15 PM
  #48
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
i second spindle that can take a corvette hub :-D
Old May 29, 2014 | 11:49 AM
  #49
Termn8r's Avatar
Car: 1989 Iroc Z28 Convertible
Engine: V8 5.0 305 TBI
Something fairly easy would be billet caps for everything under the hood. Oil stick, oil cap, radiator cap, water cap, windshield fluid cap etc. Make them covers with custom etching on top and color. I just spent $300 for a cap set with custom color and etching for my wife's 2012 Charger, but they don't offer anything for older Camaro's only new.
http://www.custombilletstore.com/Bil...1L_p/30010.htm
I would gladly pay for any stuff like this along with chrome covers for certain parts (like radiator, hood insets, washer/water fluid etc)
Old May 29, 2014 | 02:47 PM
  #50
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
E Brake Handle
