Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
?Rear seat belt mount Frame bracing?
Old Sep 6, 2014 | 04:37 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
I have my interior out again and I keep looking at the plates for the rear seat seat belts. It looks like a strong, flat surface that would be a great candidate for a rear tower brace. I got the idea from looking at my friend's Nissan 350Z coupe. Just curious if anyone has tried anything like this?
Old Sep 6, 2014 | 05:31 PM
Nighthawkf-117's Avatar
Car: 91' Camaro RS
Engine: 305 TBI V8
Transmission: 700/R4
Axle/Gears: Stock
Re: ?Rear seat belt mount Frame bracing?
Although i haven't tried it I think it could help improve stiffness along with other bracing. Let us know how it goes if you decide to try it.
Old Sep 9, 2014 | 11:17 AM
Pocket's Avatar
Car: 91 Trans Am
How exactly does the car flex in that area and how would a strait bar connecting the two points help anything?
Much like connecting the shock mounts, this will only add weight with zero benefit
Old Sep 9, 2014 | 03:34 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I was thinking of a bar there but to use as a harness anchor in the absence of any cage to mount to. Not sure of any stiffening benefit there.
Old Sep 11, 2014 | 09:45 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I don't see any benefit, other then extra weight.
Old Sep 11, 2014 | 10:27 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
My thought too. There are bars for fourth and fifth gen Camaros that bolt to that area but the bar is used solely for harnesses. If you can weld just do a roll bar with a bar for a harness. Shouldn't cost more than $100
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
MORREALE5
Sep 13, 2015 09:16 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
