Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
cutting 1/2" aluminum
Old Aug 15, 2017 | 04:44 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Have you guys ever cut 1/2" aluminum plate with a chop saw?
It takes 90 years with my band saw to make long cuts.
I need to make another one of these
- Joe
Attached Thumbnails cutting 1/2" aluminum-img_20170815_082822.jpg
Old Aug 15, 2017 | 06:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: cutting 1/2" aluminum
I usually use a circular saw with a carbide blade or just a jigsaw with a course blade.
Old Aug 15, 2017 | 06:55 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
6 tpi bandsaw blade would work nicely
Old Aug 15, 2017 | 07:51 PM
skinny z's Avatar
Originally Posted by AlkyIROC
..... or just a jigsaw with a course blade.
..and some candle wax.
Old Aug 15, 2017 | 09:21 PM
NoEmissions84TA's Avatar
Since it is the blade that is actually doing the cutting, don't cheap out and buy quality blades.
Whenever I have to make something like that, I use a 1/8" drill bit to drill a series of holes along the line I need to cut. Then use the jig saw to connect the dots. Smooth it out with a sander.
Old Aug 16, 2017 | 07:39 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Sounds like you need a different blade for your band saw. I just have a porta band on a stand and it eats through anything even on the mid speed settings, I have a course tooth band in there. If I crank up the speed, it is almost uncontrollable how fast it removes material.
Old Aug 16, 2017 | 08:23 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Thank you guys.
I'm using a 18 tooth per inch blade on my band saw, which is what I use for steel. I'll give a 6tpi blade a try, and perhaps some candle wax.
Thank you again for the suggestions!
-- Joe
Old Aug 18, 2017 | 11:59 PM
skinny z's Avatar
The master builder in the fab shop (I sort of helped manage) swore by his reciprocating saw and an "axe" blade for cutting thick aluminium.
https://www.milwaukeetool.ca/accesso...ing/48-00-5021
5 TPI and the wax to keep it from loading up. I wouldn't have believed it if I hadn't watched it with my own eyes.
My guess is that 6 TPI in your band saw will give similar results.
Old Aug 25, 2017 | 05:07 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Soooo..
To do large cuts, I used the chop saw with a dimensional lumber blade. Cut like butter.
For the curved cuts, I used the band saw. Took a while, but the most coarse blade I could find was 10 tpi.
Aluminum is weird.
-- Joe
Old Aug 25, 2017 | 09:25 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I use trans fluid to help keep the blades from loading up. A little messy but it works.
Old Aug 25, 2017 | 03:37 PM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
I guess I'm spoiled. I just use a cnc miller. but I do agree with the low tooth count for the saw blade.
Old Aug 26, 2017 | 02:21 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The supplier that milwaukee uses for their bandsaw is ridiculously good for how much they cost. I need to find out who makes them so I can buy the same for my fullsize bandsaw. I've been using the Olsen brand and haven't been impressed. I'll be trying Lenox next. A 14 TPI blade on that portaband is like a hot knife in butter for 3/16" and under.
Old Aug 26, 2017 | 02:25 PM
TylerSteez's Avatar
Engine: 383 stroker
I use Lenox bandsaw blades at work for steel and they're great. I believe I ordered the Lenox classic blades. Hold up very well.
Old Aug 28, 2017 | 09:38 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I have a Dewalt portaband, but I bought the Milwaukee bands too.
