88 iroc project car. Need advice about floor pans
Hey guys new to this forum. I have an 88 iroc with so many things i need to do to it but one of the first is floor pans. They are rusted out, al four of them but I'm only worried about the drivers and passengers floor pans mostly because I'm making it a 2 seater and making a custom rear interior. But the only ones i have found to replace are around 350 each. Anyone know some sort of website or camaro people who can point me in the right direction? I can weld and cut everything i just want the stock shaped pans. And ill keep you guys updated this is only day 1 so stayed tuned for the winter. I appreciate it boys i need all the advice i can get!!!!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 88 iroc project car. Need advice about floor pans
Cheaper to find a clean shell or entire car for that matter. Cut panel from the other cars or build them with your parts. Problem you will find is that there are crossmembers and subframe parts that are probably rotten out as well and are not available.
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
I put 4th gen floor pans in my car.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Back then money was worth more than time. I'd probably crush a car that needs floor pans now lol
-- Joe
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
And throw away the money for you gave for that car? Don't crush a car cause it has a few holes, give it to some kid who will enjoy it even though it has holes. Every other thread is "get another car" "crush it". It's medal, fix it it's not hard.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Kids don't want them.
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Your choices:
If its a project car, your time is irreplaceable. Choose the route that will give you greatest satisfaction with the process.
Welding floor panels is time consuming.
If you have the right tools and the patience, you will have a product to be proud of.
- crush it and replace with Prius
- find a donor and scavenge
- bite the bullet and pay for repro parts
- improvise with sheet metal patches
