Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
vacuum pump mounting..who's done it?
Old Jan 29, 2019 | 10:32 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
looking at mounting a vac pump.. at this point looks like bolting it to a front eng plate lower driver side..(under power steering pump) if I don't go Rack/pinon. Just to add vac pump..
alt is on pass side..power steering on driver side...moroso makes a braket that bolts to a eng plate.. thinking of going with it...as long as I can get it to fit under the power steering pump.
then use there parts to mount to crank..
I think I can get it in there
anybody do anything like this..? the lower 3 bolt holes on the driver side eng are open at this time..
Old Jan 29, 2019 | 08:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: vacuum pump mounting..who's done it?
I use a crank mandrel and run 3 different belts. One for the vacuum pump, one for the fuel pump and one for the alternator. Alternator is flipped around backwards because it was the only way I could make it fit.
Not sure if they have a low mount installation kit. Depending on the position, the steering box may be in the way.
https://www.gzmotorsports.com/
Old Jan 29, 2019 | 09:08 PM
steering box in way...could be. I cant tell until I get the thing installed. (eng) ya it will be run off the crank w/ mandral also..i would like to keep the set up/brackets I have now..but if I have to I can do what it takes.. from what I see the pumps bolt to the eng plate flat..if so I can make something work..
KiLLJ0Y
Jul 29, 2012 07:25 AM
levelcaraudio
Apr 29, 2010 06:16 PM
orangetang
Car Audio
Aug 10, 2004 12:20 PM
steve8586iroc
Mar 26, 2004 01:00 AM
