FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
Is there any way to use a T-5 from a M*stang in my Third Gen?
Old Oct 30, 2003 | 10:57 PM
Belstain's Avatar
Is there any way to use a t5 from a mustang in my 90 firebird?
t5's from v8 gm cars are not to be found in my area but the mustang ones are cheap and plentiful, can they be used?
Someone told me you can use them you just need the gm bellhousing. Sounds too good to be true.
Are the input shafts the same? If so could I take the guts from a ford t5 and put it in a gm v6 case?
Old Oct 31, 2003 | 12:42 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The only thing the **** T5 has in common with our T5's is five forward gears.
Input shaft length, diameter, and spline is different; cases are different, having no provision for mounting the torque arm; etc....
Pete
Old Feb 1, 2004 | 05:16 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
http://garage-scene.home.att.net/t5_...dentifying.htm
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
Cacike
Aug 27, 2015 05:10 PM
