FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
power steering bypass
Old Mar 4, 2004 | 11:18 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
I was wondering if anyone has ever used a shorter serpentine belt and routed it different to bypass the power steering pully. Does it free up enough HP to be worthwhile?? I don't plan on driving the car alot like this, just at the strip......
I already ripped out my smog pump and put a shorter belt on, and it works great.
Old May 14, 2004 | 10:43 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have done this. Does it actually work? I couldn't feel a difference, but one thing is for sure. It CAN'T hurt! I heard that it takes about 3/4 of a hp on straight line wot driving. About 2-3 hp when parallel parking. Another thing that I know works, when your car is idling, turn the wheel, and the engine slows down.
I also took the air pump off and even have a shorter belt, one for everyday driving and one belt for the strip.
LB9GTA
Old Jun 27, 2004 | 06:52 PM
copperhead110's Avatar
I wouldn't disconnect the power steering. You may need its assistance if something goes wrong at the track. You never know when you might need to turn into a skid and it would suck if you wrecked because you couldn't turn the wheel fast enough.
Old Jun 27, 2004 | 10:20 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Yeah, i did some g-tech testing and i could't realy notice a difference. Since i run street tires and have to go around the waterbox i need to make a sharp turn to get around this at my local track, and it is hard to crank that wheel with no power. i hand spun the pully at idle, and it spins freely like a skateboard wheel.....
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
