FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
fuel canister
Old Oct 19, 2005 | 07:20 PM
chevy35086's Avatar
Car: Camaro z28 1986
Axle/Gears: 3.42's
fuel canister
Hey guys Is it alright if i leave the full canister in there hooked up to the gas tank and take the other line going to the carb off? thanks let me know, as i right now i have the air system off of the car and in the spring i plan on puttin a regular 4bbl on there to replace the rochester quadrajet. emissions is not a problem as it will be registered as a limited use collector vehicle thanks in advance.
Old Oct 19, 2005 | 08:38 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
1. I wouldn't do it unless you have some sort of vent line to release pressure from the gas tank.
2. Hope you are planning to make this engine completely non-computer controlled, or at least change the distributor. The ECM is not going to play well with a non-CC carb.
Old Oct 20, 2005 | 05:20 AM
chevy35086's Avatar
Axle/Gears: 3.42's
thanks for the help, what would i have to do with the distributor? thanks
Old Oct 21, 2005 | 10:19 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
replace it with an older non cc HEI dizzy or you could pick up a new MSD unit or whatever flavor you prefer.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
92camaroJoe
Aug 13, 2015 06:07 AM
