FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
hood clearence
Old Oct 5, 2006 | 12:32 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Transmission: Borg Warner T5
Axle/Gears: 3:73
hood clearence
does anyone else here run a Edelbrock performer RPM intake(7101) on ther motor? if so will the stock hood clear it?
Old Oct 6, 2006 | 08:46 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
I do....and it does clear the stock hood. I have a Holley carb on mine...of course it takes a drop base air cleaner to make it clear.
Old Oct 6, 2006 | 10:11 AM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
Alright thanks a lot man,good to here some info.i run the 670 holly on mine too,so looks like i just need a drop base brether.and then modify it to hook up my duel snorkel ram air.
Old Oct 13, 2006 | 05:59 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
drop base cleaner and you should be good.
My edelbrock performer EPS intake and 2" regular open element air cleaner barely fits. The wing nut has about 1/8" clearance!
Old Oct 13, 2006 | 06:41 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
well my stock intake with 1'' spacer is the same height in the rear of the intake as the performer rpm.its just the front that is almost a half inch.i modded my stock breather today,and i think i'll be able to swing it,well got my fingers crossed
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
