1986 305 Trans Am 5 Spd Built ---- Colorado ---- 2500 obo
Car: 1986 Trans Am/1993 Trans Am
Engine: 305 .030 over built/ LT1 Bolt Ons
Transmission: t5/700r4
Axle/Gears: 3.43 Posi/3.23 Posi
Selling cause i have too many projects. Drivetrain is immaculate, just needs cosmetic work.
Engine - 305
.030 Over
10:1 CR
234/244 Duration .488/.510 Lift with 1.6/1.5 Roller Rockers
Stock Heads With valve job, screw in studs
Torker II Intake Manifold
Rebuilt Quadrajet Carb
HEI Distributor with 55000 Volt Coil
AC Delco Rapid Fire Plugs
Gear Drive
High Flow Oil Pump
High Output Bosch Fuel Pump
300 Miles on engine
Transmission - T5
1988 World Class
Hays Clutch Kit
Synthetic Fluid
New Seals
Rear-End -
3.23 Auburn posi new bearings, seals, 300 miles on unit
Redline Synthetic Fluid
Exterior -
Needs Rear spoiler, wrap around one is wripped
Passenger side damaged, I have door to go with and little damage on rear quarter and fender but doesn’t need replacing.
Wipers, headlights
Suspension -
WS6 Suspension
Polyurethane Bushings , not on yet
Exhaust –
Gutted Cat
Dynomax Cat-Back
Brakes –
New Pads and shoes, semi-metallic carbon
Interior –
Near Perfect condition
Dash pad is perfect, rear seat perfect, fronts are racing seats
Headliner perfect
Stock radio, no 6x9’s
Car needs to be finished as you can see, I rebuilt engine personally and bought everything off Summit Racing or AutoZone, I bought transmission too and went through it. just needs a cosmetic makeover on passenger side damage and spoiler, No AC and has heater rigged up right now but easy as 3 bolts to get it out, still has A.I.R. for emissions, needs a complete free flowing exhaust to uncap the engine, runs great off cat. All windows good, all front steering parts are perfect, needs fog lights replaced or make ram air, any questions email me.
Justin
Engine - 305
.030 Over
10:1 CR
Gear Drive
High Flow Oil Pump
300 Miles on engine
Transmission - T5
1988 World Class
Hays Clutch Kit
Synthetic Fluid
New Seals
Rear-End -
Exterior -
Wipers, headlights
Suspension -
WS6 Suspension
Exhaust –
Gutted Cat
Dynomax Cat-Back
Brakes –
Interior –
Headliner perfect
Justin
Re: 1986 305 Trans Am 5 Spd Built ---- Colorado ---- 2500 obo
pics to maverick_643@yahoo.com please thanks
It is turn key, the cam was too much for the stock studs so i took heads off to put screw-in-studs in and am shaving em port and polish too, then it will be back up running, sorry to delay internet was down for a couple days and i've been working 60+ hours a week. Just put the posi unit in and have been able to break it in considering heads arent on yet. email me back zeikjds@gmail.com if your interested.
justin
justin
3rdgenparts
Aug 6, 2015 09:03 AM
