[OH] 84 trans am lt1 t 56 swap 425 horsepower
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Hey guys, I have a roller 84 trans am. The body is great with only a few tiny surface rust spots. It comes with 4 extra fenders, 2 extra side skirts, and a extra nose cone. This car has kyb lowering springs and adjustable struts all the way around. It also has Lakewood sway bars, lower control arms, adjustable panhard bar, wonder bar, 9 bolt Borg Warner rear end with 3.45 limited slip that works great and has no play. This car is sitting on black honeyNcomb wheels. I have a formula power buldge hood to go on it. I have a manual shifter console that's in the car, and good 4th gen seats too.
The motor is a 93 lt1/ t56 combo from a 93 camaro z28. This is the more desireable tranny with no skip ship and the lower gearing. I recently bought a comp cam 503 camshaft, new comp cams 1.6 roller rockers, new comp cams push rods, new guide plates, arp 7/16 screw in studs, comp cams roller lifters, new le2 porter lt1 heads, new le porter intake manifold, bbk 52 mm throttle body, aeromotive fpr and brand new 8.5 mm plug wires. When this motor is put together it should lay down 400 rwhp easily. It will stomp holes in ls1 cars. I also have a brand new wiring harness that pocket made for me. He intigrated the 93 harness into my cars original harness to make this a plug and play swap. I bought a new bell housing and clutch fork for his as well. I really need to sell this project as I just found out my wife is pregnant with our first Child
I will show a list of my money invested.
$1500 roller firebird chassis
$2500 lt1/t56 with 23k on both
$1300 le2 heads
$250 le ported intake
$150 bbk throttle body
$750 valve train items
$450 wiring harness
$125 short throw shifter
$1000 suspension parts
$200 9 bolt rear end
plus slot more that I deffiently can't remember right now. As you can see I have over 8200$ invested in a car that just needs bolted up. It should run low 12s easily, and still get 25 mpg on the street.
I would love to get $6100 out of all of this. I'm located in zanesville, Ohio 43701.
You can call or text me at 740-819-7601 or post here.
$1300 le2 heads
$450 wiring harness
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
