Firebirds Wanted Looking to buy a specific Firebird? Post your Want Ad here.
wtb 3g firebird/ta parts car in Ky or south IN/ohio
Old May 6, 2006 | 03:21 PM
formulated's Avatar
Car: 1988 firebird formula
welp the title says it all looking to spend under 1000
Old May 18, 2006 | 12:44 PM
BlackBird20's Avatar
Car: 88 Formula 350
Engine: Hopes and Dreams
Transmission: Slush Box
Axle/Gears: 9 Bolt, 3.27
I have a 88 Formula 350 Hartop.... White
Original L98, no wiring or engine though, 165K on car
Perfectly Good 700-R4 included, torque converted and flexplate also
BW 9-bolt, Posi, 3.27, Aluminum driveshaft
WS6, 36mm front, 24mm rear sway bars, quick ratio steering gear...obviously
Dual electric fans
4 Wheel disc- Brand new calipers, rotors, pads... ZERO MILES
Will have Brand new front calipers, rotors, pads next week... Will have ZERO MILES
In process of running brake and fuels lines, NO COMPRESSION FITINGS USED
In process of painting engine bay black
Amost done with wiring for carb or aftermarket setup, WILL retain factory gauges.... 140mph speedo, 8K tach, oil, temp, fuel, volts
SOLID underbody
Surface rust on body, little work needed. Looks ugly now but one weekend worth of work and she'll be beautiful!! I may do the body work soon, but i'll need more cash
No rear spoiler
Two power pull down assemblies come with it
No rear seats, Interior carpet and front seats could need replaced, show wear
Grant pn# 838 Steering wheel
Aftermarket throttle cable for carb, or can be used for TPI, I havent cut it to length yet or put on the throttle fitting, but is run and attacthed to pedal
I'm located in Mansfield Ohio....As the car sits with new brake and fuel lines, and calipers, pads, rotors, I would need $750
Also, only quality pads are used, i.e. Bendix Titanium Metallic, I don't use cheap crap... Brake and Fuel lines are coated, not bare steel... Will not have fuel pump, for another $100, a Holley Blue electric inline with regulator will be installed...
Thanks, Bob
TA8487
Aug 16, 2015 12:21 PM
TheScaryOne
Classified Ads Feedback Board
Dec 26, 2010 10:26 PM
6948ric
Jul 12, 2009 10:46 AM
