MISSING RPO's
Old Nov 6, 2002 | 10:15 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
MISSING RPO's
My RPO's in my 86 IROC were ripped out so I would like to know if there is some place that I could get info on my RPO's. Would GM deal with this?? Do I have to Apply some where?? All I want to know is where can I find my MISSING RPO's
Old Nov 7, 2002 | 03:35 AM
LetsRock's Avatar
Car: 1989 Trans Am GTA
Engine: LB9 TPI with L98 cam (Manual car)
Transmission: T5 5Speed/ 9bolt Borg-Warner 3.45 gears with posi
I believe you can go to a GM dealer and give them your VIN and if they still have 1986 info in their databases they can print out the info for you. If that doesnt work get the info from Pontiac Historical Services , this site has links to PHS and all the info you need is there on PHS's website.
Old Nov 7, 2002 | 04:03 PM
90TA's Avatar
PHS won't have anything for an IROC.
Old Nov 7, 2002 | 05:48 PM
4L60bliss's Avatar
Neither will the dealer, its way to old. '90-92 if your lucky. 93+ definatly.
Old Nov 8, 2002 | 03:19 AM
LetsRock's Avatar
Excuse me, the CHEVY equivilent.
Old Nov 8, 2002 | 03:52 PM
BORLAZ06's Avatar
I have the same problem...cant find any RPO codes in my car. Looks like my last resort is the chevy dealer.
Old Nov 8, 2002 | 04:44 PM
4L60bliss's Avatar
Borla, if your car is indeed a '92, I can probably save you the trip to the dealer. Shoot me your VIN.
Old Nov 8, 2002 | 08:21 PM
BORLAZ06's Avatar
ite.... 1G1FP23F9NL143478
Old Nov 11, 2002 | 01:11 PM
4L60bliss's Avatar
Borla, sorry it took so long, your car is to old, so I couldn't look it up at the house, I had to go to work and look it up.
Here ya go:
  • AC3
  • AJ3
  • AM9
  • AR9
  • AU3
  • A31
  • A90
  • B18
  • B34
  • B35
  • B84
  • C49
  • C60
  • DC4
  • DG7
  • D34
  • D42
  • D5S
  • D8M
  • D81
  • E5Z
  • E9Z
  • FE2
  • GU6
  • G80
  • G92
  • IP2
  • J65
  • KC4
  • K34
  • K68
  • LB9
  • MK6
  • MM5
  • NA5
  • NN5
  • NP5
  • N10
  • N64
  • N96
  • QLC
  • R9Z
  • T96
  • UB3
  • UN6
  • UQ1
  • U79
  • VAN
  • VG8
  • VK3
  • V73
  • YA7
  • YF5
  • Z28
  • 1AZ
  • 1SD
  • 1SZ
  • 19Q
  • 41U
  • 6ZW
  • 7ZW
  • 8NL
  • 82I
  • 822
  • 829
  • 84P
  • 9NL
Old Nov 11, 2002 | 01:20 PM
BORLAZ06's Avatar
Thanks alot for your time...gunna check out the RPOS now and see the truth behind my car.
Old Nov 11, 2002 | 01:38 PM
BORLAZ06's Avatar
G92 : AXLE REAR RATIO, PERFORMANCE
KC4 : COOLING SYSTEM, ENG OIL
GU6 : AXLE REAR, 3.42 RATIO
MK6 : TRANSMISSION, MAN 5 SPD, B0RG WARNER, 2.95 1ST, O/D
N64 : WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
Unable to locate code R9Z in our database!
Unable to locate code IP2 in our database!
1AZ : Order Modification, Orders Sold (or: CUSTOMER ORDERED VEHICLE)
Unable to locate code YA7 in our database!
Thanks once again 4L60.
Old Nov 11, 2002 | 05:03 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
4L60, you wouldn't have info. for a 1990 model car, wouldja? It's a convertible, and while I know that they sometimes put the convertible RPO stickers in weird locations, I can't seem to find mine anywhere.
Old Nov 11, 2002 | 08:13 PM
4L60bliss's Avatar
Sure, I'll try, but:
A) I can't garuntee being a '90 model
B) I'm not doing everybody on the boards VIN
Old Nov 11, 2002 | 11:38 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
Yo I'm just curious I have this RPO code for my tranny, why is yours different???
M39 : TRANSMISSION, MAN 5 SPD B0RG WARNER, 77MM, 2.95
Old Nov 12, 2002 | 01:58 AM
BORLAZ06's Avatar
I dunno why yours is different. Maybe cause the car was assembled in Canada I noticed thirdgens from there a bit different. RPOs seem different too. Dont know the exact reason why.
edit: Looks like our thirdgens were assembled in Van Nuys, CA.
Fireslash
Apr 11, 2016 06:43 PM
sammy52401
Nov 11, 2015 07:20 PM
BrianI
Oct 3, 2015 12:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
lewandom
Oct 1, 2015 08:15 AM
